When you have master slaves configuration , the web interface take in consideration for the checks witch slave?
or in case of active active configuration , in witch node the web interface takes into consideration ?
is that possible to configure priority for it? first one node and then second node?
Thanks in adavance.
master and salves configuration
- Former Nagios Staff
Re: master and salves configuration
I'm not entirely sure what you are talking about. Can you point to a specific piece of our documentation where we talk about masters and slaves? Perhaps you mean parents and children?
Can you point out a particular host or service and the configs I should be looking at?
Then, can you PM me your Profile? You can download it by going to Admin > System Config > System Profile and click the ***Download Profile*** button towards the top. If for whatever reason you *cannot* download the profile, please put the output of View System Info (5.3.4+, Show Profile if older) in the thread (that will at least get us some info). This will give us access to many of the logs we would otherwise ask for individually. If security is a concern, you can unzip the profile take out what you like, and then zip it up again. We may end up needing something you remove, but we can ask for that specifically.
You can also generate a profile manually using the script at /usr/local/nagiosxi/html/includes/components/profile/getprofile.sh
That should generate a profile in /usr/local/nagiosxi/var/components/ which you can get off the server with an application such as FileZilla.
If you get an error that PROFILE BUILD FAILED, please see https://support.nagios.com/kb/article.p ... ategory=44
