Modifying notification template
linearstack
Post by linearstack »
How can we modify text notification message to html notification in NagiosXI ?
npolovenko
Re: Modifying notification template
Post by npolovenko »
Hello, @linearstack. It is possible to use html formatting inside the notification message templates. Otherwise, you could use one of the plugins from the exchange to send html alerts. Take a look here: https://exchange.nagios.org/index.php?o ... ml%20alert
Let me know if this helps.
linearstack
Thanks npolovenko, using html formatting in notification message worked. :)
Post by dwhitfield »
It sounds like this issue has been resolved. Is it okay if we lock this thread? Thanks for choosing the Nagios forums!
linearstack
yes, you can. :)
