I can't clone a host/service
jtintegration
Post by jtintegration »
I usually able to clone a host/service but no longer able to. The error message does not tell me much. Please let me know how to fix, enclosed is a screenshot.
thanx
npolovenko
Re: I can't clone a host/service
Post by npolovenko »
@jtintegration, You probably have other errors in your current configs. I'd recommend reverting to a good configuration snapshot.
You could also run the following command to check the current configs for errors:
Also, if you click on the "View Output" icon next to the failed config snapshot you will see more specific onformation on why it failed.
jtintegration
Here is the config log for one of the failed event:
Nagios Core 4.2.4
Last Modified: 12-07-2016
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 490 services.
Checked 259 hosts.
Checked 1 host groups.
Checked 0 service groups.
Error: Contact 'test' has no service notification commands defined!
Error: Contact 'test' has no host notification commands defined!
Checked 4 contacts.
Checked 2 contact groups.
Checked 124 commands.
Checked 9 time periods.
Checked 0 host escalations.
Checked 259 hosts
Checked 0 host dependencies
Checked 9 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 2
***> One or more problems was encountered while running the pre-flight check...
npolovenko
@jtintegration, I see that you have 2 errors in your configs.
To fix that please navigate to the Core Configurations Manager, then click on contacts in the left column. Find the 'test' contact in the list and open it. Open the tab that says "Alert Settings". In Manage Host Notification Commands select xi_host_notification_handler, and in Manage Service Notification Commands select xi_service_notifications_handler. Save the config. And then Apply Configuration.
