I have installed the Nagios3 into my server HP Proliant DL380 G5 which is running on Linux Mint. According from the installation instruction, Nagios3 has pre-created on Linux Mint so I just insert command lines to run the installation. I got the locahost webpage but wouldn't located the host configuration files. All I have in /etc/nagios3 are contacts_nagios2.cfg, extifo_nagios2.cfg, generic-host_nagios2, localhost_nagios2, services_nagios2, timeperiod_nagios2, apache2, cgi, commands, htpasswd, nagios, resource. Please help so I can continue to get my work done.
thank you so much
wouldn't located host.cfg file in Linux Mint Nagios3
Re: wouldn't located host.cfg file in Linux Mint Nagios3
hosts.cfg file should be in the objects folder. Can you run in terminal?
If this file doesn't exist, you can create it, for example:
# updatedb
# locate hosts.cfgCode: Select all
# vi hosts.cfg
use generic-host
host_name web
alias Web Server
address 192.168.0.55
}Be sure to check out our Knowledgebase for helpful articles and solutions!
thanks for your reply. I didn't see the file exit, so I create the content inside the terminal. but how to save it as a configuration file? or do you mean creating one text file in ~/nagios/etc/objects?
when I restart the nagios service, it shows error: Restaring nagios (via systemctl): job failed. see system logs and "systemctl status for detail". [failed]. and it's unable to connect to localhost.
would you please advice..
thanks again
thanks again
When you run "vi hosts.cfg", you create a config file. Your host has to have some services as well. In a similar way, you can create a services.cfg file in the objects directory if you don't have it, for example:
You should probably check to see if you have these paths (to the hosts.cfg and services.cfg) set in the nagios.cfg file. Check also if the commands that you are using are actually defined in commands.cfg.
To verify the configuration, you run in terminal:
Check for warnings and errors. If you see any errors, you should fix them first, otherwise you are not going to restart nagios.
Note: I don't have Nagios installed on Mint but I think, that this is the correct path for you (to verify the configuration). Mine is different:
Hope this helps.
# vi services.cfg
host_name web
service_description HTTP
check_command check_http
}To verify the configuration, you run in terminal:
# /usr/local/nagios/bin/nagios -v /etc/nagios3/nagios.cfgNote: I don't have Nagios installed on Mint but I think, that this is the correct path for you (to verify the configuration). Mine is different:
# /usr/bin/nagios3 -v /usr/local/nagios/etc/nagios.cfgBe sure to check out our Knowledgebase for helpful articles and solutions!
I swap out Linux Mint since it didn't work out well and now having Ubuntu 11.10 running. Although I follow the instructions in the link you sent (also on Nagios documents for quick start installation), the hosts.cfg still not appear in my system files (/etc/nagios3/conf.d). As you suggested in the earlier notes, I tried to create a config file for hosts. I ran # vi hosts.cfg and add the define hosts info in the content, however, this config file is a plain text document (text/plain) type and when restart the nagios service, it's still not showing up in the localhosts/nagios.
