I don't seem to be able to find it in the doco - how can I check version of NCPA agent running on the host . I tried check_ncpa.py -H <hostname> -V
It returns 1.1.1 which I presume is the version of check_ncpa.py command, not NCPA agent itself
Genna
How to check NCPA agent version
Re: How to check NCPA agent version
Here's an example of checking the NCPA agent version:
Let us know if you have any more questions.
[root@main-nagios-xi ~]# /usr/local/nagios/libexec/check_ncpa.py -H <remote ip> -t 'mytoken' -P 5693 -M system/agent_version
OK: Agent_version was ['2.1.1']Be sure to check out our Knowledgebase for helpful articles and solutions!
Thanks for your reply.
That works. I wondered if there is a way to do so on the host itself, not from Nagios Server (for Puppet automation for example) But will do for now.
Thanks again,
Genna
Thanks again,
Genna
npolovenko
- Support Tech
@genna, You could run a curl command on a host to get the ncpa version:
curl -k -XGET "https://localhost:5693/api/system/agent_version?token=mytoken"As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
That will do the trick
npolovenko
- Support Tech
@genna, No problem. I'll go ahead and lock this topic for you.
