Our latest apply config never completes. received messages:
Error: Contact 'OEMTeam' has no service notification commands defined!
Error: Contact 'OEMTeam' has no host notification commands defined!
Deleted contact group OEMTeam and still happens(including messages above). Follows pattern set in https://support.nagios.com/kb/article/n ... 1488288749
except for the last manual run of reconfigure.sh...I DO NOT get prompted for password so not sure is sudo issue.
is there a simple out?
Here is general error page text.
Reset config permissions failed.
An error occurred while attempting to apply your configuration to Nagios Core. Monitoring engine configuration files have been rolled back to their last known good checkpoint.
Try Again View Snapshot
Write host configurations ...
Configuration file: ca200.infra.cinfin.com.cfg successfully written!
Host configuration files successfully written!
Write service configurations ...
Service configuration files successfully written!
Configuration file: hostgroups.cfg successfully written!
Configuration file: servicegroups.cfg successfully written!
Configuration file: hosttemplates.cfg successfully written!
Configuration file: servicetemplates.cfg successfully written!
Configuration file: timeperiods.cfg successfully written!
Configuration file: commands.cfg successfully written!
Configuration file: contacts.cfg successfully written!
Configuration file: contactgroups.cfg successfully written!
Configuration file: contacttemplates.cfg successfully written!
Configuration file: servicedependencies.cfg successfully written!
Configuration file: hostdependencies.cfg successfully written!
Configuration file: serviceescalations.cfg successfully written!
Configuration file: hostescalations.cfg successfully written!
Configuration file: serviceextinfo.cfg successfully written!
Configuration file: hostextinfo.cfg successfully written!
Apply config never completes "contact xyz has no....
jkelly1959
jkelly1959
Re: Apply config never completes "contact xyz has no....
Hold on this till morning....we did get prompted for password on command line entry. Will attempt fix from other post in am and reply here.
- Former Nagios Staff
If you aren't able to resolve the issue yourself, it might be worth posting the sudoers file here (or opening a ticket to do so) just as a sanity check.jkelly1959 wrote: so not sure is sudo issue.
jkelly1959
OK looks as part of our audit process the master sudoers file overwrites the systems sudoers. We are working with the linux admins to get the updates returned. Will update when they have and problem is resolved.
Yes, the missing entries in the sudoers file would cause the issue you are having.
Let us know if you need any other help.
jkelly1959
suduers corrected...All working as before
Thanks all who gave input@!
kyang
Sounds good!
Did you have any more questions or are we okay to lock this up?
