Switch monitor when community string has special chars
tonkaUser
Post by tonkaUser »
Our SNMP community string has special characters (! and &). If we use the wizard to configure Network Switch / Router, then the services do not work and we need to escape special characters. We have 10s of routers/switches to monitor. Each of the port statuses has the port number, so we cannot use Bulk Modification tool.
I want config files to be created with the escaped community string.
I started looking at /usr/local/nagiosxi/html/includes/configwizards/switch/switch.inc.php. Is that the right approach to hack this page so configs are generated correctly? Is there an update that we can take that will escape special chars?
Re: Switch monitor when community string has special chars
Take a look at User Macros, muuuuch easier: https://assets.nagios.com/downloads/nag ... Macros.pdf
tonkaUser
Post by tonkaUser »
Once I define the community string as a macro (with escaped special chars), how would I tell network wizard to use that when generating the config files?
npolovenko
Post by npolovenko »
@tonkaUser, Yes, you'd define macros in:
/usr/local/nagios/etc/resource.cfg
$USER7$=User*!name
$USER8$=Pass*!Word
Then restart Nagios and use macros inside the wizard:
service nagios restart
tonkaUser
Post by tonkaUser »
Thanks. I added the macro.
Just to confirm. I still need to change /usr/local/nagiosxi/html/includes/configwizards/switch/switch.inc.php:1027 to refer to the newly created macro instead of using $snmpopts['snmpcommunity'] right ?
When I used the wizard, I did not see an option to select a macro for SNMP community string.
Thanks!
tonkaUser
Post by tonkaUser »
I changed switch.inc.php to use a user macro and it seems to work. It's a little bit hacky, but I will take it.
tacolover101
Post by tacolover101 »
tonkaUser wrote:I changed switch.inc.php to use a user macro and it seems to work. It's a little bit hacky, but I will take it.
you went the hacky way bud. that's the great thing about IT - always a solution. :-)
with what the folks above were mentioning - you'd substitute $USER8$ in place of your community string, which Nagios would then parse to reference your comm string.
tonkaUser
Post by tonkaUser »
When you said "you'd substitute $USER8$ in place of your community string, " do you mean I can do it using Nagios UI? WOuld I do it when using the wizard or after the wizard was ran to change all the services that were affected?
Thanks!
kyang
Post by kyang »
Thanks @tacolover101 for the help!
@tonkaUser, Yes, you would use $USER8$ (which is your community string in resource.cfg)
Typing in $USER8$ in the community string option when using the Network/switch wizard, would use your special characters password.
Let us know if you have any more questions!
tonkaUser
Post by tonkaUser »
Thanks. It's clear what you meant now.
I defined $USER9$ as a community string that has all special characters escaped.
I just tried to use $USER9$ as the SNMP community string for the router/switch wizard and the wizard had a problem connecting to the device. I think the issue is that the wizard needs to take SNMP community as-is without escaping special chars when it connects to the device. When the wizard is generating the config files, the special chars should be escaped (e.g. when "check_command" adds the SNMP string, it has to use the escaped version). It feels that the wizard should have smarts to escape any special chars.
Thanks for your help all. It's resolved.
