Nagios Dashboard Filtering
SrinivasanNSL
Post by SrinivasanNSL »
HI Team,
Can you please advice me how to use Nagios Log Server Dashboard Filtering. I want to know exactly how many servers and what are all the servers reporting to Log server also I want to Filter with Specific IP address to check the logs. Please assist.
kyang
Re: Nagios Dashboard Filtering
Post by kyang »
Are you using the latest version of Nagios Log Server?
If you click on report in the NLS home page. It brings you to a page called "unique hosts"
That should list what hosts are sending and what host are not sending to NLS anymore.
This documentation shows how to check logs with a specific IP address. It's fairly easy, in the sense that you type in the IP address of your host and click the green search button.
https://assets.nagios.com/downloads/nag ... Server.pdf
Let us know if you have any more questions!
