Hi there,
I was wondering the other day, wether this is know bug or if this is an issue caused by my installation.
When I go to the map in the webinterface and select another layout (e.g. from Balanced Tree (Horizontal) to Circular Markup), suddenly every host is shown twice. When I just hit the map-link in the navigation everything is fine once again - at least as long as I don't chang the layout.
This happened on 2 seperate and independent nagios core installations. Both had the core-version 4.3.4.
Is this a known issue (couldn't find anything with the search)? And is there a fix I can implement?
Bug in Map?
Re: Bug in Map?
I have confirmed this behavior and filed a bug report here
https://github.com/NagiosEnterprises/na ... issues/471
Thanks!
Thanks!
Re: Bug in Map?
Hi there. I have same bug with new map. my tree was duplicated when i add second host. on legacy map all ok, tree not duplicated. version 4.3.4
Is this bug will fix in next version?
- Former Nagios Staff
Re: Bug in Map?
As this appears to be a different issue than the one above, I am locking this thread and we can work through it in https://support.nagios.com/forum/viewto ... 999#bottom
