Trouble installing a plugin
I am having issues installing the plug in listed below. I attempted the install instructions on their readme but it seems some of the files are missing. It may also be that i have made a mistake. Can someone assist me?
The Plugin
https://github.com/thecodeteam/nagios-unity
The error i am getting at install:
No local packages or download links found for docopt>=0.6.2
error: Could not find suitable distribution for Requirement.parse('docopt>=0.6.2')
Thanks.
The Plugin
Thanks.
npolovenko
- Support Tech
Re: Trouble installing a plugin
@angus, Have you used the pip instructions or the git instructions to install the plugin? What is the version of your OS?
I used the python setup below. I manually download the package and unzipped it in the /tmp dir. I am using Centos. I am not familiar with the PIP install options. Should i investigate PIP and go that route?
$ cd nagios-unity
$ sudo python setup.py install
$ cd nagios-unity
npolovenko
- Support Tech
@angus, Not really, I only asked that so I could go the same route and try to reproduce the problem.
You should install the docopt package:
If you don't have pip you need to install it:
Let me know how it goes.
pip install docopt==0.6.2Code: Select all
easy_install pipAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Once I installed via PIP, i attempt to use the commands but i get an odd response. What is going on here?
/]# nagios-unity --help
Traceback (most recent call last):
File "/usr/bin/nagios-unity", line 5, in <module>
from pkg_resources import load_entry_point
File "/usr/lib/python2.6/site-packages/pkg_resources.py", line 2655, in <module>
working_set.require(__requires__)
File "/usr/lib/python2.6/site-packages/pkg_resources.py", line 648, in require
needed = self.resolve(parse_requirements(requirements))
File "/usr/lib/python2.6/site-packages/pkg_resources.py", line 546, in resolve
raise DistributionNotFound(req)
pkg_resources.DistributionNotFound: urllib3>=1.21.1
Thanks.
Thanks.
npolovenko
- Support Tech
@angus, You may still be missing some of the required modules. Please run this command:
I installed the plugin with one command:
And it seemed like python automatically downloaded all the dependent packages for me.
So then i ran:
And haven't gotten any errors.
pip install urllib3Code: Select all
pip install nagios-unitySo then i ran:
/usr/bin/nagios-unity -helpAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Even after performing those commands, i still have the same issue.
~]# /usr/bin/nagios-unity -help
I removed the two packages, urllib3 and nagios-unity, and reinstalled them. now i get a new set of errors.
/]# nagios-unity
File "/usr/bin/nagios-unity", line 7, in <module>
from nagiosunity.cli.client import main
File "/usr/lib/python2.6/site-packages/nagiosunity/cli/client.py", line 52, in <module>
from nagiosunity.lib import utils
File "/usr/lib/python2.6/site-packages/nagiosunity/lib/utils.py", line 17, in <module>
import bitmath
File "/usr/lib/python2.6/site-packages/bitmath/__init__.py", line 58, in <module>
import argparse
ImportError: No module named argparse
Thanks.
/]# nagios-unity
import bitmath
import argparse
Thanks.
I installed python-argparse manually and am now presented with the following:
File "/usr/lib/python2.6/site-packages/nagiosunity/cli/client.py", line 54, in <module>
from nagiosunity import commands
File "/usr/lib/python2.6/site-packages/nagiosunity/commands/__init__.py", line 47
commands_dict = {cmd.name: cmd for cmd in COMMANDS}
SyntaxError: invalid syntax
Thanks.
Thanks.
kyang
Thanks for posting the errors, but since this isn't a plugin available in our nagios-plugins package.
It's probably best if you report these issues to the maintainer of this plugin.
https://github.com/thecodeteam/nagios-unity/issues
The last commit was in Dec 2017, so they seem fairly on point in terms of updates.
