Graphs for the same service of different hosts at one page?
smersh
Post by smersh »
It is possible to plot multiple graphs of the same service for several different hosts at the same page? Yes, it is possible with the Multistacked Performance Graphs, but it needs to point hosts and services every time.
For example I have 20 servers and I want to see their CPU temperatures graphs altogether.
Regards!
Nick Jandieri.
smersh
Re: Graphs for the same service of different hosts at one pa
Post by smersh »
I have eventually found a solution, a kind off.
Seeing graphs for the service group is possible from the Availability Report. Advanced options have a "Display service perfdata" checkbox, checking it displays what I need. However - without a respect of the general graph displaying settings and with the textual availability report itself beside.
kyang
Post by kyang »
Glad you found a solution.
Did you have any more questions or are we okay to lock this up?
smersh
Post by smersh »
I would still like to see just graphs without any additional data. BTW, this is easily achievable with Nagios Core and Nagiosgraph.
Regards!
NJ
kyang
Post by kyang »
We are a bit out, but in XI 6.0 graphing will be getting a complete overhaul.
https://www.nagios.com/roadmaps/
smersh
Post by smersh »
Ok, thank you for the encouraging information.
Regards!
NJ
kyang
Post by kyang »
No problem!
smersh
Post by smersh »
Sure, you can lock it.
Thanks!
kyang
Post by kyang »
Sounds good! I'll be closing this thread!
If you have any more questions, feel free to create another thread.
Thanks for using the Nagios Support Forum!
