Hi team,
We have one requirement that we need to give the report for hostgroup.
EX: The hostgroup availability report should be have 20:00 hr to 07:00 hrs.
That means we should get the availability report daily basis from particular period of time. We have seen the report we can send 24 hrs,yesterday,week,year and Quartly and Custom. And in custom we have no option daily basis.
But We need the report daily basis from particular time period. Can anybody help
Can we enable the my schedule report daily basis
npolovenko
- Support Tech
Re: Can we enable the my schedule report daily basis
@Gonela, I submitted a feature request to add a 12-hour lookback period option. When this feature gets added you'd just schedule a daily 12hr report and choose to receive it at 7 am. That way the report will actually run at 7 am and collect the data for the past 12 hours, so 7am - 12hours. That should give you the report for the time period specified.
Hi Team,
Thanks for the reply, its not 12 hr report. In future if we need 10 hrs report how we can get the report again you need send the feature. The problem is we are not able to get the report daily basis. if we add the feature daily basis for nagios xi that is good so we can enable the report from what time to what time and when.
npolovenko
- Support Tech
@Gonela, Turns out there is already a feature to use a custom report time period(under the advanced tab you can choose a custom time period). So that way you create time periods in CCM from 22:00-24:00 and 00:00-07:00. And then the report runs automatically every 24 hours but only considers the periods specified earlier. However, this feature did not work as expected for me. So I filed a bug report. After this bug gets patched I'll be able to test this out and be able to better assist you. You can check back with me or other support team member in a few weeks to inquire about a status, but I wouldn't expect this to be fixed until the 5.5 release.
