Hi All,
Could you please help me with the below requirement is possible with Nagios or not
->I have log file and i need to configure a threshold for the last record in that log file and raise a mail when it cross the threshold. Is this possible with Nagios core.
->I want to run a DB query and monitor the output of that query by keeping a threshold for that output. Is this possible
Nagios DB Query Monitoring
Re: Nagios DB Query Monitoring
Yup, check_log3 is the plugin I would recommend for this.vnoc wrote:->I have log file and i need to configure a threshold for the last record in that log file and raise a mail when it cross the threshold. Is this possible with Nagios core.
Also, Nagios Log Server has a free tier and can do this.
Depends on the DBMS used, but generally yes there's plugins for every major DBMS. I know for a fact this can be done with MariaDB/MySQL and SQL Server if using the correct plugin.vnoc wrote:->I want to run a DB query and monitor the output of that query by keeping a threshold for that output. Is this possible
- Former Nagios Staff
