Hello, I need to customize the responses of check_snmp and for that I want to edit and compile the plugins again but I can not find the correct way to do it.
can you help me?
Thank you
Compile Nagios Plugins.
Re: Compile Nagios Plugins.
Here's the source:
https://github.com/nagios-plugins/nagios-plugins
Here's check_snmp:
https://github.com/nagios-plugins/nagio ... eck_snmp.c
Change check_snmp.c to your liking, then compile the project and the altered check_snmp binary should be produced.
Here's how to compile nagios-plugins from source:
https://support.nagios.com/kb/article/n ... e-569.html
Here's check_snmp:
- Former Nagios Staff
