Do you have any ideas what to do if CPU check via WMI returns the below message?
(Our NagiosXI version is 2011R1.9, remote server OS is Windows Server Enterprise 2008, SP2)
UNKNOWN: Could not retrieve all required data. =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=
INTERNAL ERROR: Signal 6 in pid 28868 (4.0.0alpha3-GIT-UNKNOWN)
Please read the file BUGS.txt in the distribution
PANIC: internal error
BACKTRACE: 20 stack frames:
#0 /usr/bin/wmic(call_backtrace+0x2b) [0x85f15a3]
#1 /usr/bin/wmic(smb_panic+0x266) [0x85f18dd]
#2 /usr/bin/wmic [0x85f1a78]
#3 /usr/bin/wmic(fault_setup+0) [0x85f1aad]
#4 [0x807420]
#5 /lib/libc.so.6(abort+0x101) [0x29b701]
#6 /usr/bin/wmic [0x863b167]
#7 /usr/bin/wmic [0x863b23c]
#8 /usr/bin/wmic [0x863b447]
#9 /usr/bin/wmic [0x863b794]
#10 /usr/bin/wmic(talloc_named_const+0x1f) [0x863c476]
#11 /usr/bin/wmic(ndr_pull_WbemQualifiers+0x194) [0x80b9431]
#12 /usr/bin/wmic(ndr_pull_WbemClass+0x26b) [0x80bbd82]
#13 /usr/bin/wmic(ndr_pull_DataWithStack+0xd3) [0x80b97f0]
#14 /usr/bin/wmic(ndr_pull_WbemClassObject+0x30b) [0x80bacaf]
#15 /usr/bin/wmic(WBEMDATA_Parse+0xef6) [0x80b7693]
#16 /usr/bin/wmic(IEnumWbemClassObject_SmartNext+0x4e7) [0x80b7dc5]
#17 /usr/bin/wmic(main+0x50b) [0x80b45cf]
#18 /lib/libc.so.6(__libc_start_main+0xdc) [0x286e9c]
#19 /usr/bin/wmic [0x80b3a91]
INTERNAL ERROR: Signal 6 in pid 28949 (4.0.0alpha3-GIT-UNKNOWN)
#4 [0x678420]
CPU check via WMI not working
Re: CPU check via WMI not working
What version of wmi are you using?
Try running from the command line this commands and post the output:
# cd /usr/local/nagios/libexec
# ./check_wmi_plus.pl --versionCode: Select all
# ./check_wmi_plus.pl -H <your_windows_server_IP_address> -u <username> -p <password> -m checkcpu -w 80 -c 90Be sure to check out our Knowledgebase for helpful articles and solutions!
Also,
what version of wmic is installed:
/usr/local/bin/wmic --version
