NCPA 2.1.1 disk metrics
angus
Post by angus »
I am trying to use NCPA 2.1.1 but i am not seeing the same options in the Nagios Config Wizard that i usually see with NCPA 1.8.1. I've attached a screen shot displaying the missing sections.
kyang
Re: NCPA 2.1.1 disk metrics
Post by kyang »
Have you updated the Config Wizard? Should be on 1.5.3, if not you can update it.
Go to Admin > System Extensions > Manage Config Wizards, click on "Check for Updates", then click on "Install Updates".
angus
Post by angus »
That did it! thanks a ton. I didn't even know that was there.
Thanks.
kyang
Post by kyang »
Sounds good!
Did you have any more questions on this or are we okay to lock this up?
angus
Post by angus »
No more questions, please lock.
kyang
Post by kyang »
Sounds good! I'll be closing this thread!
If you have any more questions, feel free to create another thread.
Thanks for using the Nagios Support Forum!
