Hi team,
I don't know if its posible (give me an alternative) but we would like to do it.
For example, for a remote server, execute an api "https://ip/nagiosxi/api" specifying the host name, service name, status (critical, arning,..) and description.
If it's not posible can you give me an alternative ?
Thanks a lot
Submit service update trhough Nagios API
kyang
Re: Submit service update trhough Nagios API
Are you trying to get a single service update?
Going into the XI Home Page --> Help --> Under Rest API Docs you will see --> Object reference. (Look at the parameters and examples for help.)
Something like this will get 1 record of the service status for Ping which is under the host_name localhost/
Is this what you were looking for?
curl -XGET "http://192.168.4.125/nagiosxi/api/v1/objects/servicestatus?apikey=t0bMmNo0qFu70qFZO93e8sSIqREI82WV2nHna5oTZc0gWFgK4ier47qOe4smlohm&pretty=1&host_name=localhost&service_description=Ping&records=1"Code: Select all
"instance_id": "1",
"service_id": "148",
"host_id": "143",
"host_name": "localhost",
"host_alias": "localhost",
"name": "PING",
"host_display_name": "",
"host_address": "127.0.0.1",
"display_name": "PING",
"status_update_time": "2018-02-06 16:04:45",
"status_text": "PING OK - Packet loss = 0%, RTA = 0.04 ms",
"status_text_long": "",
"current_state": "0",
"performance_data": "rta=0.039000ms;100.000000;500.000000;0.000000 pl=0%;20;60;0",
"should_be_scheduled": "1",
"check_type": "0",
"last_state_change": "2017-12-01 20:07:04",
"last_hard_state_change": "2017-05-13 23:17:34",
"last_hard_state": "0",
"last_time_ok": "2018-02-06 16:04:41",
"last_time_warning": "1969-12-31 18:00:00",
"last_time_critical": "2017-12-01 14:46:57",
"last_time_unknown": "1969-12-31 18:00:00",
"last_notification": "1969-12-31 18:00:00",
"next_notification": "1969-12-31 18:00:00",
"no_more_notifications": "0",
"acknowledgement_type": "0",
"current_notification_number": "0",
"process_performance_data": "1",
"obsess_over_service": "1",
"event_handler_enabled": "1",
"modified_service_attributes": "0",
"event_handler": "",
"check_command": "check_ping!100.0,20%!500.0,60%!!!!!!",
"normal_check_interval": "5",
"retry_check_interval": "1",
"check_timeperiod_id": "125",
"icon_image": "",
"icon_image_alt": "",
"has_been_checked": "1",
"current_check_attempt": "1",
"max_check_attempts": "4",
"last_check": "2018-02-06 16:04:41",
"next_check": "2018-02-06 16:09:41",
"state_type": "1",
"notifications_enabled": "1",
"problem_acknowledged": "0",
"flap_detection_enabled": "1",
"is_flapping": "0",
"percent_state_change": "0",
"latency": "0",
"execution_time": "4.003",
"scheduled_downtime_depth": "0",
"passive_checks_enabled": "1",
"active_checks_enabled": "1"
Hi kyang,
It seems to be what I search.
Only one question, how we can get the API key ?
Eric
Eric
kyang
Sounds good.
The API key is generated for you and stays the same.
You will see it in the help (Rest API docs) on the example cURL request commands.
Hi kyang,
Thanks for your time.
I'm sorry but i can't see what you say, below i attach you our "Help" menu in nagiosXI.
Eric
Eric
kyang
Sorry, I should have gotten the version of your XI.
You are using a very old XI version. Which uses the backend API --> The backend API is now deprecated.
The API key for the backend API is located here
Go to: Admin->Manage Components->Backend API URL->select your user from the "User" drop-down menu->Apply Settings.
Example:
Example:
I would suggest installing the new XI version 5.4.12 to get access to the new REST API which will have these documentations in the help section.&username=test&ticket=0b6o4ukv0serk6jeq6ko9isn7sbl2qnv6tn9pb8q5jjnp65hbn9k939fuj4teoth
Thank you very much kyang
We'll have a look on the upgrade.
By the way, when I launch the curl from another server i get this error. Maybe because i have an old version, the curl api path are different:
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p>The requested URL /nagiosxi/api/v1/objects/servicestatus was not found on this server.</p>
<hr>
</body></html>
The url of curl is: curl -XGET "http://server-ip/nagiosxi/api/v1/object ... &records=1"
By the way, I check installed components and i see the "backend api" ( i attach you a pic) but i can't choose a user in scroll.
Thanks for your help once again
<html><head>
</head><body>
<h1>Not Found</h1>
<hr>
</body></html>
I attach you the screen that I have to choose a user
kyang
I'm not entirely sure why that is happening.
It's probably best to take a look at upgrading or installing a clean system with the new XI version if you don't have much hosts or services.
Yes, because the older version is using the backend API. Whereas, the new version is using the Rest API and provides great documentation on using it.By the way, when I launch the curl from another server i get this error. Maybe because i have an old version, the curl api path are different:
Thanks kyang,
We will take a look on upgrade.
Regards
Regards
