Nagios core 3
This support forum board is for questions relating to Nagios Fusion.
sltn_support
Nagios core 3
Post by sltn_support »
Is it possible to add a Nagios core 3 server to fusion 4.x?
eloyd
Cool Title Here
Re: Nagios core 3
Post by eloyd »
From the first, non-video result of Google by searching for "Nagios Fusion Core" I found this document: https://assets.nagios.com/downloads/nag ... erview.pdf
In it, it says:
Monitoring Server Requirements
Nagios Fusion can integrate with the following Nagios monitoring servers:
• Nagios XI version 2009R1.3 or later
• Nagios Core 3.2.2 or later
You will need to figure it out from here. :)
npolovenko
Re: Nagios core 3
Post by npolovenko »
@eloyd, This article hasn't been updated for Fusion 4. Fusion 4 doesn't support any 3.x versions of Nagios Core. I believe that's because a never version uses JSON to pull the data, and that wasn't introduced until Core 4.x
eloyd
Cool Title Here
Re: Nagios core 3
Post by eloyd »
So, depending on which version of Fusion you're running, it may support it, it may not. Time to update the article? :-)
npolovenko
Re: Nagios core 3
Yep, that should be corrected shortly.
