How can we monitor pnp4nagios and integrated with NCPA?
rohithroki
Hello Experts,
As we are migrating from Nsclient++ to NCPA agent.
we need to monitor the pnp4nagios performance graph with historical data via NCPA.
Please help me how to configure ?
cheers,
Simbu
cheers,
Simbu
kyang
Re: How can we monitor pnp4nagios and integrated with NCPA?
Are you talking about merging RRDs?
Could you explain more about what you are trying to accomplish?
rohithroki
Hi Kyang,
Yes.can we able to merge RRD.
I need to know whether NCPA client ( windows,Linux) will able to monitor the performance graph via pnp4nagios.
If yes,how can we monitor and need to know the configuration level changes.
Thanks in Advance.
Cheers,
Simbu
Thanks in Advance.
Cheers,
Simbu
kyang
NCPA generates perfdata as long as the plugin you are using generates it too.
May I ask the plugin you are using?
rohithroki
Hi Kyang,
Thanks for the reply.
We are using pnp4nagios plugin for performance graph Monitoring.
How can we use this plugin to the NCPA clients to see the historical data along with performance graph.
Cheers,
Simbu
Cheers,
Simbu
rohithroki
Hi Kyang,
I am attaching the perfdata XML config files of the host.Please check and let me know
Cheers,
Simbu
Cheers,
Simbu
- windows_testserver.zip
- (208.81 KiB) Downloaded 416 times
It's still not exactly clear what is is you're trying to do. I'll answer this question directly:
And here's a slightly more cut-down version of that script:
https://gist.github.com/arantius/2166343
Unfortunately I have never used either of this scripts by-hand. You might need to play around with them to get the desired results.
Yes, you can merge RRD files. @Box293's Performance Data Tool (** THIS WILL NOT WORK IN NAGIOS CORE. IT WAS DESIGNED FOR NAGIOS XI.) does this with the push of a button in Nagios XI. Here's the underlying script responsible for that action, which should work with pnp4nagios generated RRDs:rohithroki wrote:Yes.can we able to merge RRD.
#!/usr/bin/python
# vim: ts=4 sw=4 expandtab :
# Copyright 2010 Javier Ruere
# Copyright 2011 Christian Theune <[email protected]>
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program. If not, see <http://www.gnu.org/licenses/>.
import copy
from itertools import izip
import logging
from optparse import OptionParser
import os
import tempfile
__version__ = '0.1.2'
LOGGER = logging.getLogger('merge-rrds')
# The best ElementTree implementation available.
ET = None
def import_element_tree():
"""Returns the best implementation of ElementTree it can find."""
try:
from xml.etree import cElementTree
LOGGER.info('Using C ET implementation.')
return cElementTree
except ImportError:
pass
try:
# No C code.
from xml.etree import ElementTree
LOGGER.info('Using Python ET implementation.')
return ElementTree
except ImportError:
pass
try:
# Python < 2.4.
from elementtree import ElementTree
try:
# Just check if the lib is available.
import xml.parsers.expat
LOGGER.info('Using Python 3rd party ET implementation.')
except ImportError:
# No expat, now things will get really slow.
from elementtree import SimpleXMLTreeBuilder
ElementTree.XMLTreeBuilder = SimpleXMLTreeBuilder.TreeBuilder
LOGGER.warn('Using very slow XML parser! You might want to check '
'your setup.')
return ElementTree
except ImportError:
LOGGER.error('Failed to find an ElementTree implementation. '
'Please install one.')
return None
def compare_element_texts(el1, el2, expressions, errmsg=''):
for expr in expressions:
if el1.findtext(expr) != el2.findtext(expr):
LOGGER.error('%s "%s" differs.', errmsg, expr)
return False
return True
RRA_COMPATIBILITY_PROPERTIES = ( './cf', './pdp_per_row' )
def are_rra_compatible(n_rra, o_rra):
"""Checks for compatibility at the RRA level."""
return compare_element_texts(n_rra, o_rra, RRA_COMPATIBILITY_PROPERTIES,
'RRAs are not compatible.')
RRD_COMPATIBILITY_PROPERTIES = ( './version', './step' )
def check_compatibility(et1, et2):
"""Checks for compatibility at the RRD level."""
msg = 'RRDs are not compatible.'
if not compare_element_texts(et1, et2, RRD_COMPATIBILITY_PROPERTIES, msg):
raise AssertionError(msg)
def generate_rrd(et, rrd_or_xml_fn):
write_xml = rrd_or_xml_fn.lower().endswith('.xml')
if write_xml:
xml = open(rrd_or_xml_fn, 'w')
else:
xml = tempfile.NamedTemporaryFile()
try:
# XXX There must be a way to do this correctly.
xml.write('<?xml version="1.0" encoding="utf-8"?>\n')
et.write(xml, encoding="utf-8")
if write_xml:
ret = 0 # Already finished!
else:
xml.flush()
ret = os.system("rrdtool restore -f -r '%s' '%s'"
% (xml.name.replace("'", r"\'"),
rrd_or_xml_fn.replace("'", r"\'")))
finally:
xml.close()
if ret:
LOGGER.critical("Failed to create merged rrd '%s'. (%d)", rrd_or_xml_fn,
ret)
else:
LOGGER.info("Created merged rrd '%s'.", rrd_or_xml_fn)
def create_empty_row(rra_et):
field_count = len(rra_et.find('./database/row').findall('v'))
assert field_count > 0, "Rows with no elements don't make sense."
row_et = ET.Element('row')
for _ in range(field_count):
v_et = ET.SubElement(row_et, 'v')
v_et.text = 'NaN'
return row_et
def database2dict(row_elems, total, lastupdate, step, sparse=False):
"""Create a dict with the non NaN data from database."""
times = xrange(lastupdate - total * step, lastupdate + step, step)
data = {}
for time, row_elem in izip(times, row_elems):
for value_elem in row_elem:
# This is useful for sparse files (which is my case).
# XXX Could be avoided for mostly full files for a speedup.
if 'NaN' not in value_elem.text:
data[time] = row_elem
break
return data
def merge_rrd_xml(old_et, new_et):
log = logging.getLogger('merge-rrds.merge_rrd_xml')
# Get some parameters to calculate the time of the rows.
step_elem = new_et.find('./step')
step = int(step_elem.text)
n_lastupdate_elem = new_et.find('./lastupdate')
n_lastupdate = int(n_lastupdate_elem.text)
assert step == int(old_et.find('./step').text)
o_lastupdate = int(old_et.find('./lastupdate').text)
assert o_lastupdate < n_lastupdate
new_timeframe = n_lastupdate - o_lastupdate
# Create the merged tree and add the configuration.
root = ET.Element('rrd')
version_elem = ET.SubElement(root, 'version')
version_elem.text = '0003' # This version is generated.
root.append(copy.deepcopy(step_elem))
root.append(copy.deepcopy(n_lastupdate_elem))
n_dses = new_et.findall('./ds')
assert len(n_dses) == len(old_et.findall('./ds')), \
"RRDs have different number of DSes."
if [ ds.findtext('./name') for ds in n_dses ] \
!= [ n.text for n in old_et.findall('./ds/name') ]:
log.warn("RRDs have DSes with different names")
for n_ds in n_dses:
root.append(copy.deepcopy(n_ds))
for n_rra, o_rra in izip(new_et.findall('./rra'), old_et.findall('./rra')):
if not are_rra_compatible(n_rra, o_rra):
raise AssertionError('Incompatible RRAs.')
n_rows = n_rra.findall('./database/row')
o_rows = o_rra.findall('./database/row')
assert len(n_rows) == len(o_rows)
# Compute the cut-off-point between the old and the new RRA
pdp_per_row = int(n_rra.find('./pdp_per_row').text)
keep_new_rows = new_timeframe / (pdp_per_row*step)
old_rows = len(n_rows) - keep_new_rows
old_rows = max(old_rows, 0)
# Create the merged RRA and add the configuration.
m_rra = ET.SubElement(root, 'rra')
m_rra.append(copy.deepcopy(n_rra.find('./cf')))
m_rra.append(copy.deepcopy(n_rra.find('./pdp_per_row')))
m_rra.append(copy.deepcopy(n_rra.find('./params')))
m_rra.append(copy.deepcopy(n_rra.find('./cdp_prep')))
if old_rows:
merged_rows = o_rows[-old_rows:]+ n_rows[old_rows:]
else:
merged_rows = n_rows
assert len(merged_rows) == len(n_rows)
db_elem = ET.SubElement(m_rra, 'database')
for x in map(copy.deepcopy, merged_rows):
db_elem.append(x)
return ET.ElementTree(root)
def get_xml(*rrd_or_xml_fns):
"""Returns an ElementTree of the dump of each given filename.
Using the extension, the file type is inferred. If the file is an XML,
it is read directly. If it's an RRD, it's dumped and then read.
xml_streams = []
for rrd_or_xml_fn in rrd_or_xml_fns:
if rrd_or_xml_fn.lower().endswith('.xml'):
xml_streams.append(open(rrd_or_xml_fn))
else:
if not rrd_or_xml_fn.lower().endswith('.rrd'):
LOGGER.warn('Unknown file type. Guessing it is an RRD.')
xml_streams.append(os.popen(
"rrdtool dump '%s'" % (rrd_or_xml_fn.replace("'", r"\'"))))
return [ ET.parse(xml_stream) for xml_stream in xml_streams ]
def get_configuration():
parser = OptionParser(version="%prog v" + __version__,
usage="%prog <old rrd> <new rrd> <merged rrd>")
parser.add_option("-v", "--verbose", action="count", default=0,
help="produce more output")
options, args = parser.parse_args()
if len(args) != 3:
parser.error("Wrong number of arguments.")
return [ options ] + args
def main():
options, old_fn, new_fn, merged_fn = get_configuration()
logging.basicConfig()
LOGGER.setLevel(max(logging.DEBUG, logging.WARNING - options.verbose * 10))
global ET
ET = import_element_tree()
if ET is None:
return 1
LOGGER.info("Merging '%s' and '%s', where the latter has precedence, into "
"'%s'.", old_fn, new_fn, merged_fn)
old_et, new_et = get_xml(old_fn, new_fn)
check_compatibility(old_et, new_et)
merged_et = merge_rrd_xml(old_et, new_et)
generate_rrd(merged_et, merged_fn)
return 0
if __name__ == '__main__':
import sys
sys.exit(main())
kyang
Thanks for the help @mcapra!
rohithroki, let us know if you have any more questions.
Or please further explain what you are trying to do.
rohithroki
Hi Mcapra & Kyang,
Sorry for the inconvenience..
I will pitch you directly.
We are currently testing the NCPA client on windows and Linux servers ,instead of Nsclient ++ agent.
In Nsclient ++ and NRPE agents ,we have the host monitored in the Nagios portal and option called (Perform Extra host actions ) highlighting in the attachment.
But in NCPA agent,we don't have the option.How to get and add the option into the NCPA clients.Please find the screenshot of the NCPA client.
Thanks in advance..
Cheers,
Simbu
Thanks in advance..
Cheers,
Simbu
kyang
Thanks for showing us.
Are you using this with nagiosgraph correct? How did you get the graphs for other services?
