Nagios not sending out notifications
jkinning
Post by jkinning »
We had experienced a network outage and when everything came back online Nagios XI kept sending out notifications. I thought they were queued up somewhere but after readying this thread I discovered they were in the database. https://support.nagios.com/forum/viewto ... 7&start=50
I ran this command which stopped them but now going forward no notifications are being sent except the test notifications that are manually executed.
echo "UPDATE xi_events SET status_code=2, processing_time=NOW() WHERE event_type=2;"| psql nagiosxi nagiosxi
I ran the database_repair script which corrected some errors it said but the notifications that were working in large volumes have stopped but unfortunately all notifications have stopped. I can look under the notifications and see where Nagios XI shows the Critical and OK and who they should be sent to but they are not getting received which they once were. I am thinking there is more to the above command that i ran than just purging the notifications.
Just need help getting this back to working order.
jkinning
Re: Nagios not sending out notifications
Post by jkinning »
Very strange but looks like at 5am Nagios started sending out all the OK messages. I ran that command again to stop the madness but not sure why it is doing that. 8 hours later sending out OK for all the systems.
Is there a way to stop the email floods when a network outage occurs? Disable notifications didn't have any impact.
I am running Nagios XI 5.4.12
jkinning
Post by jkinning »
I think things looks alright but now getting this message
Database Maintenance (dbmaint) stale (20509 seconds old), Database Maintenance (dbmaint) stale (20509 seconds old)
npolovenko
Post by npolovenko »
Hello, @jkinning.
If the alert emails were already scheduled in the mailing queue disabling notifications won't do anything. Depending on how your XI email was set up, you may be able to run a sendmail clear queue command, or something similar.
The best ways to deal with alert flooding include:
1) Creating parent-child relationships between hosts and services. So that way if a host server goes down XI will automatically know not to send any notifications for its services.
2) Adjusting the "notification_interval" and "max_check_attempts" options to limit the final number of alerts.
3) Adjusting what kind of notifications you want to receive
4) Using scheduled downtime or disabling alerts before a host or services go down.
In the XI web interface click on the admin menu, then Reset Security Credentials in the left column. Don't change anything and just click on Update Credentials.
Also, run:
service crond restart
If that doesn't help please upload the /etc/cron.d/nagiosxi file, and this log /usr/local/nagiosxi/var/dbmaint.log
jkinning
Post by jkinning »
Here is one file, attached. I renamed it to .txt. The log file was about a GB which didn't attach so here is the last several lines of the log file.
OPTIMIZING NAGIOSQL TABLE: tbl_user
SQL: OPTIMIZE TABLE tbl_user
    <p><pre>SQL Error [nagiosxi] : FATAL:  terminating connection due to administrator command
FATAL:  terminating connection due to administrator command</pre></p>
Repair Complete: Removing Lock File
PHP Notice:  Unknown: Cannot set connection to blocking mode in Unknown on line 0
CREATING: /usr/local/nagiosxi/var/dbmaint.lock
CLEANING ndoutils TABLE 'commenthistory'...
SQL: DELETE FROM nagios_commenthistory WHERE entry_time < FROM_UNIXTIME(1486652101)
CLEANING ndoutils TABLE 'processevents'...
SQL: DELETE FROM nagios_processevents WHERE event_time < FROM_UNIXTIME(1486652101)
CLEANING ndoutils TABLE 'externalcommands'...
SQL: DELETE FROM nagios_externalcommands WHERE entry_time < FROM_UNIXTIME(1517583301)
CLEANING ndoutils TABLE 'logentries'...
SQL: DELETE FROM nagios_logentries WHERE logentry_time < FROM_UNIXTIME(1510412101)
CLEANING ndoutils TABLE 'notifications'...
SQL: DELETE FROM nagios_notifications WHERE start_time < FROM_UNIXTIME(1510412101)
CLEANING ndoutils TABLE 'contactnotifications'...
SQL: DELETE FROM nagios_contactnotifications WHERE start_time < FROM_UNIXTIME(1510412101)
CLEANING ndoutils TABLE 'contactnotificationmethods'...
SQL: DELETE FROM nagios_contactnotificationmethods WHERE start_time < FROM_UNIXTIME(1510412101)
CLEANING ndoutils TABLE 'statehistory'...
SQL: DELETE FROM nagios_statehistory WHERE state_time < FROM_UNIXTIME(1455116101)
CLEANING ndoutils TABLE 'timedevents'...
SQL: DELETE FROM nagios_timedevents WHERE event_time < FROM_UNIXTIME(1518187801)
CLEANING ndoutils TABLE 'systemcommands'...
SQL: DELETE FROM nagios_systemcommands WHERE start_time < FROM_UNIXTIME(1518187801)
CLEANING ndoutils TABLE 'servicechecks'...
SQL: DELETE FROM nagios_servicechecks WHERE start_time < FROM_UNIXTIME(1518187801)
CLEANING ndoutils TABLE 'hostchecks'...
SQL: DELETE FROM nagios_hostchecks WHERE start_time < FROM_UNIXTIME(1518187801)
CLEANING ndoutils TABLE 'eventhandlers'...
SQL: DELETE FROM nagios_eventhandlers WHERE start_time < FROM_UNIXTIME(1518187801)
TIME TO OPTIMIZE
LASTOPT:  1518180301
INTERVAL: 60
NOW:      1518188101
OPTTIME:  1518183901
OPTIMIZING NDOUTILS TABLE: nagios_acknowledgements
SQL: OPTIMIZE TABLE nagios_acknowledgements
OPTIMIZING NDOUTILS TABLE: nagios_commands
SQL: OPTIMIZE TABLE nagios_commands
OPTIMIZING NDOUTILS TABLE: nagios_commenthistory
SQL: OPTIMIZE TABLE nagios_commenthistory
OPTIMIZING NDOUTILS TABLE: nagios_comments
SQL: OPTIMIZE TABLE nagios_comments
OPTIMIZING NDOUTILS TABLE: nagios_configfiles
SQL: OPTIMIZE TABLE nagios_configfiles
OPTIMIZING NDOUTILS TABLE: nagios_configfilevariables
SQL: OPTIMIZE TABLE nagios_configfilevariables
OPTIMIZING NDOUTILS TABLE: nagios_conninfo
SQL: OPTIMIZE TABLE nagios_conninfo
OPTIMIZING NDOUTILS TABLE: nagios_contact_addresses
SQL: OPTIMIZE TABLE nagios_contact_addresses
OPTIMIZING NDOUTILS TABLE: nagios_contact_notificationcommands
SQL: OPTIMIZE TABLE nagios_contact_notificationcommands
OPTIMIZING NDOUTILS TABLE: nagios_contactgroup_members
SQL: OPTIMIZE TABLE nagios_contactgroup_members
OPTIMIZING NDOUTILS TABLE: nagios_contactgroups
SQL: OPTIMIZE TABLE nagios_contactgroups
OPTIMIZING NDOUTILS TABLE: nagios_contactnotificationmethods
SQL: OPTIMIZE TABLE nagios_contactnotificationmethods
OPTIMIZING NDOUTILS TABLE: nagios_contactnotifications
SQL: OPTIMIZE TABLE nagios_contactnotifications
OPTIMIZING NDOUTILS TABLE: nagios_contacts
SQL: OPTIMIZE TABLE nagios_contacts
OPTIMIZING NDOUTILS TABLE: nagios_contactstatus
SQL: OPTIMIZE TABLE nagios_contactstatus
OPTIMIZING NDOUTILS TABLE: nagios_customvariables
SQL: OPTIMIZE TABLE nagios_customvariables
OPTIMIZING NDOUTILS TABLE: nagios_customvariablestatus
SQL: OPTIMIZE TABLE nagios_customvariablestatus
OPTIMIZING NDOUTILS TABLE: nagios_dbversion
SQL: OPTIMIZE TABLE nagios_dbversion
OPTIMIZING NDOUTILS TABLE: nagios_downtimehistory
SQL: OPTIMIZE TABLE nagios_downtimehistory
OPTIMIZING NDOUTILS TABLE: nagios_eventhandlers
SQL: OPTIMIZE TABLE nagios_eventhandlers
OPTIMIZING NDOUTILS TABLE: nagios_externalcommands
SQL: OPTIMIZE TABLE nagios_externalcommands
OPTIMIZING NDOUTILS TABLE: nagios_flappinghistory
SQL: OPTIMIZE TABLE nagios_flappinghistory
OPTIMIZING NDOUTILS TABLE: nagios_host_contactgroups
SQL: OPTIMIZE TABLE nagios_host_contactgroups
OPTIMIZING NDOUTILS TABLE: nagios_host_contacts
SQL: OPTIMIZE TABLE nagios_host_contacts
OPTIMIZING NDOUTILS TABLE: nagios_host_parenthosts
SQL: OPTIMIZE TABLE nagios_host_parenthosts
OPTIMIZING NDOUTILS TABLE: nagios_hostchecks
SQL: OPTIMIZE TABLE nagios_hostchecks
OPTIMIZING NDOUTILS TABLE: nagios_hostdependencies
SQL: OPTIMIZE TABLE nagios_hostdependencies
OPTIMIZING NDOUTILS TABLE: nagios_hostescalation_contactgroups
SQL: OPTIMIZE TABLE nagios_hostescalation_contactgroups
OPTIMIZING NDOUTILS TABLE: nagios_hostescalation_contacts
SQL: OPTIMIZE TABLE nagios_hostescalation_contacts
OPTIMIZING NDOUTILS TABLE: nagios_hostescalations
SQL: OPTIMIZE TABLE nagios_hostescalations
OPTIMIZING NDOUTILS TABLE: nagios_hostgroup_members
SQL: OPTIMIZE TABLE nagios_hostgroup_members
OPTIMIZING NDOUTILS TABLE: nagios_hostgroups
SQL: OPTIMIZE TABLE nagios_hostgroups
OPTIMIZING NDOUTILS TABLE: nagios_hosts
SQL: OPTIMIZE TABLE nagios_hosts
OPTIMIZING NDOUTILS TABLE: nagios_hoststatus
SQL: OPTIMIZE TABLE nagios_hoststatus
OPTIMIZING NDOUTILS TABLE: nagios_instances
SQL: OPTIMIZE TABLE nagios_instances
OPTIMIZING NDOUTILS TABLE: nagios_logentries
SQL: OPTIMIZE TABLE nagios_logentries
OPTIMIZING NDOUTILS TABLE: nagios_notifications
SQL: OPTIMIZE TABLE nagios_notifications
OPTIMIZING NDOUTILS TABLE: nagios_objects
SQL: OPTIMIZE TABLE nagios_objects
OPTIMIZING NDOUTILS TABLE: nagios_processevents
SQL: OPTIMIZE TABLE nagios_processevents
OPTIMIZING NDOUTILS TABLE: nagios_programstatus
SQL: OPTIMIZE TABLE nagios_programstatus
OPTIMIZING NDOUTILS TABLE: nagios_runtimevariables
SQL: OPTIMIZE TABLE nagios_runtimevariables
OPTIMIZING NDOUTILS TABLE: nagios_scheduleddowntime
SQL: OPTIMIZE TABLE nagios_scheduleddowntime
OPTIMIZING NDOUTILS TABLE: nagios_service_contactgroups
SQL: OPTIMIZE TABLE nagios_service_contactgroups
OPTIMIZING NDOUTILS TABLE: nagios_service_contacts
SQL: OPTIMIZE TABLE nagios_service_contacts
OPTIMIZING NDOUTILS TABLE: nagios_servicechecks
SQL: OPTIMIZE TABLE nagios_servicechecks
OPTIMIZING NDOUTILS TABLE: nagios_servicedependencies
SQL: OPTIMIZE TABLE nagios_servicedependencies
OPTIMIZING NDOUTILS TABLE: nagios_serviceescalation_contactgroups
SQL: OPTIMIZE TABLE nagios_serviceescalation_contactgroups
OPTIMIZING NDOUTILS TABLE: nagios_serviceescalation_contacts
SQL: OPTIMIZE TABLE nagios_serviceescalation_contacts
OPTIMIZING NDOUTILS TABLE: nagios_serviceescalations
SQL: OPTIMIZE TABLE nagios_serviceescalations
OPTIMIZING NDOUTILS TABLE: nagios_servicegroup_members
SQL: OPTIMIZE TABLE nagios_servicegroup_members
OPTIMIZING NDOUTILS TABLE: nagios_servicegroups
SQL: OPTIMIZE TABLE nagios_servicegroups
OPTIMIZING NDOUTILS TABLE: nagios_services
SQL: OPTIMIZE TABLE nagios_services
OPTIMIZING NDOUTILS TABLE: nagios_servicestatus
SQL: OPTIMIZE TABLE nagios_servicestatus
OPTIMIZING NDOUTILS TABLE: nagios_statehistory
SQL: OPTIMIZE TABLE nagios_statehistory
OPTIMIZING NDOUTILS TABLE: nagios_systemcommands
SQL: OPTIMIZE TABLE nagios_systemcommands
OPTIMIZING NDOUTILS TABLE: nagios_timedeventqueue
SQL: OPTIMIZE TABLE nagios_timedeventqueue
OPTIMIZING NDOUTILS TABLE: nagios_timedevents
SQL: OPTIMIZE TABLE nagios_timedevents
OPTIMIZING NDOUTILS TABLE: nagios_timeperiod_timeranges
SQL: OPTIMIZE TABLE nagios_timeperiod_timeranges
OPTIMIZING NDOUTILS TABLE: nagios_timeperiods
SQL: OPTIMIZE TABLE nagios_timeperiods
CLEANING nagiosxi TABLE 'commands'...
SQL: DELETE FROM xi_commands WHERE processing_time < 1518159301::abstime::timestamp without time zone
CLEANING nagiosxi TABLE 'events'...
SQL: DELETE FROM xi_events WHERE processing_time < 1518159301::abstime::timestamp without time zone
SQL1: SELECT xi_meta.meta_id FROM xi_meta LEFT JOIN xi_events ON xi_meta.metaobj_id=xi_events.event_id WHERE metatype_id='1' AND event_id IS NULL
LOCKFILE '/usr/local/nagiosxi/var/dbmaint.lock' EXISTS - EXITING!
LOCKFILE '/usr/local/nagiosxi/var/dbmaint.lock' IS OLD - REMOVING
SQL: DELETE FROM nagios_commenthistory WHERE entry_time < FROM_UNIXTIME(1486654201)
SQL: DELETE FROM nagios_processevents WHERE event_time < FROM_UNIXTIME(1486654201)
SQL: DELETE FROM nagios_externalcommands WHERE entry_time < FROM_UNIXTIME(1517585401)
SQL: DELETE FROM nagios_logentries WHERE logentry_time < FROM_UNIXTIME(1510414201)
SQL: DELETE FROM nagios_notifications WHERE start_time < FROM_UNIXTIME(1510414201)
SQL: DELETE FROM nagios_contactnotifications WHERE start_time < FROM_UNIXTIME(1510414201)
SQL: DELETE FROM nagios_contactnotificationmethods WHERE start_time < FROM_UNIXTIME(1510414201)
SQL: DELETE FROM nagios_statehistory WHERE state_time < FROM_UNIXTIME(1455118201)
SQL: DELETE FROM nagios_timedevents WHERE event_time < FROM_UNIXTIME(1518189901)
SQL: DELETE FROM nagios_systemcommands WHERE start_time < FROM_UNIXTIME(1518189901)
SQL: DELETE FROM nagios_servicechecks WHERE start_time < FROM_UNIXTIME(1518189901)
SQL: DELETE FROM nagios_hostchecks WHERE start_time < FROM_UNIXTIME(1518189901)
SQL: DELETE FROM nagios_eventhandlers WHERE start_time < FROM_UNIXTIME(1518189901)
LASTOPT:  1518188101
INTERVAL: 60
NOW:      1518190201
OPTTIME:  1518191701
SQL: DELETE FROM xi_commands WHERE processing_time < 1518161401::abstime::timestamp without time zone
SQL: DELETE FROM xi_events WHERE processing_time < 1518161401::abstime::timestamp without time zone
SQL: DELETE FROM nagios_commenthistory WHERE entry_time < FROM_UNIXTIME(1486656301)
SQL: DELETE FROM nagios_processevents WHERE event_time < FROM_UNIXTIME(1486656301)
SQL: DELETE FROM nagios_externalcommands WHERE entry_time < FROM_UNIXTIME(1517587501)
SQL: DELETE FROM nagios_logentries WHERE logentry_time < FROM_UNIXTIME(1510416301)
SQL: DELETE FROM nagios_notifications WHERE start_time < FROM_UNIXTIME(1510416301)
SQL: DELETE FROM nagios_contactnotifications WHERE start_time < FROM_UNIXTIME(1510416301)
SQL: DELETE FROM nagios_contactnotificationmethods WHERE start_time < FROM_UNIXTIME(1510416301)
SQL: DELETE FROM nagios_statehistory WHERE state_time < FROM_UNIXTIME(1455120301)
SQL: DELETE FROM nagios_timedevents WHERE event_time < FROM_UNIXTIME(1518192001)
SQL: DELETE FROM nagios_systemcommands WHERE start_time < FROM_UNIXTIME(1518192001)
SQL: DELETE FROM nagios_servicechecks WHERE start_time < FROM_UNIXTIME(1518192001)
SQL: DELETE FROM nagios_hostchecks WHERE start_time < FROM_UNIXTIME(1518192001)
SQL: DELETE FROM nagios_eventhandlers WHERE start_time < FROM_UNIXTIME(1518192001)
TIME TO OPTIMIZE
LASTOPT:  1518188101
INTERVAL: 60
NOW:      1518192301
OPTTIME:  1518191701
SQL: DELETE FROM xi_commands WHERE processing_time < 1518163501::abstime::timestamp without time zone
SQL: DELETE FROM xi_events WHERE processing_time < 1518163501::abstime::timestamp without time zone
SQL: DELETE FROM nagios_commenthistory WHERE entry_time < FROM_UNIXTIME(1486658401)
SQL: DELETE FROM nagios_processevents WHERE event_time < FROM_UNIXTIME(1486658401)
SQL: DELETE FROM nagios_externalcommands WHERE entry_time < FROM_UNIXTIME(1517589601)
SQL: DELETE FROM nagios_logentries WHERE logentry_time < FROM_UNIXTIME(1510418401)
SQL: DELETE FROM nagios_notifications WHERE start_time < FROM_UNIXTIME(1510418401)
SQL: DELETE FROM nagios_contactnotifications WHERE start_time < FROM_UNIXTIME(1510418401)
SQL: DELETE FROM nagios_contactnotificationmethods WHERE start_time < FROM_UNIXTIME(1510418401)
SQL: DELETE FROM nagios_statehistory WHERE state_time < FROM_UNIXTIME(1455122401)
SQL: DELETE FROM nagios_timedevents WHERE event_time < FROM_UNIXTIME(1518194101)
SQL: DELETE FROM nagios_systemcommands WHERE start_time < FROM_UNIXTIME(1518194101)
SQL: DELETE FROM nagios_servicechecks WHERE start_time < FROM_UNIXTIME(1518194101)
SQL: DELETE FROM nagios_hostchecks WHERE start_time < FROM_UNIXTIME(1518194101)
SQL: DELETE FROM nagios_eventhandlers WHERE start_time < FROM_UNIXTIME(1518194101)
LASTOPT:  1518192301
INTERVAL: 60
NOW:      1518194401
OPTTIME:  1518195901
SQL: DELETE FROM xi_commands WHERE processing_time < 1518165601::abstime::timestamp without time zone
SQL: DELETE FROM xi_events WHERE processing_time < 1518165601::abstime::timestamp without time zone
npolovenko
@jkinning, Let's kill the stalled dbmaint process.
Run this command to find out the process PID number.
ps aux | grep dbmaint
And then kill the process with:
kill process_pid_number
After that let's run the database repair script:
/usr/local/nagiosxi/scripts/repair_databases.sh
jkinning
Post by jkinning »
Ok, then what do I need to do?
I killed all these
[root@nagiosl1p ~]# ps aux | grep [d]bmaint
nagios    4715  0.0  0.0 106076  1292 ?        Ss   10:30   0:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php >> /usr/local/nagiosxi/var/dbmaint.log 2>&1
nagios    4722  5.3  5.5 2301552 1839260 ?     S    10:30   8:28 /usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php
nagios   28412  0.0  0.0 106076  1288 ?        Ss   12:15   0:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php >> /usr/local/nagiosxi/var/dbmaint.log 2>&1
nagios   28424  5.4  5.0 2157824 1660096 ?     S    12:15   2:55 /usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php
nagios   33853  0.0  0.0 106076  1288 ?        Ss   11:05   0:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php >> /usr/local/nagiosxi/var/dbmaint.log 2>&1
nagios   33869  5.3  5.3 2250488 1775680 ?     S    11:05   6:35 /usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php
nagios   39025  0.0  0.0 106076  1292 ?        Ss   09:55   0:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php >> /usr/local/nagiosxi/var/dbmaint.log 2>&1
nagios   39034  5.6  5.7 2360980 1901252 ?     S    09:55  10:52 /usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php
nagios   59357  0.0  0.0 106076  1292 ?        Ss   12:50   0:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php >> /usr/local/nagiosxi/var/dbmaint.log 2>&1
nagios   59366  5.7  4.8 2110680 1601344 ?     S    12:50   1:05 /usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php
nagios   63958  0.0  0.0 106076  1288 ?        Ss   11:40   0:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php >> /usr/local/nagiosxi/var/dbmaint.log 2>&1
nagios   63974  5.3  5.2 2206644 1720968 ?     S    11:40   4:47 /usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php
The repair_database script has completed as well.
REPAIR COMPLETE
Stopping ndo2db: done.
Starting ndo2db: done.
Running configuration check...
Stopping nagios:. done.
Starting nagios: done.
nagios database repair succeeded
nagiosql database repair succeeded
npolovenko
@jkinning, Alright, let us know if see any more stale dbmaint messages.
jkinning
Post by jkinning »
I just got one
***** Nagios XI Alert *****
Nagios has detected a problem with this service.
Notification Type: PROBLEM
Service: Nagios XI Jobs
Host: nagiosl1p
Address:
State: CRITICAL
Info:
Database Maintenance (dbmaint) stale (31609 seconds old), Database Maintenance (dbmaint) stale (31609 seconds old)
Date/Time: 2018-02-09 12:54:08
npolovenko
@jkinning, Please run the following command:
chage -I -1 -m 0 -M 99999 -E -1 nagios
Then:
After that, if you see the same error again, please send us the latest cron log from: /var/log/cron
