Missing repo index update in *.xml.gz
emssa
Post by emssa »
We had to pull these down and run a createrepo against the directory, please fix.
Re: Missing repo index update in *.xml.gz
Can you please provide some more information? I'm not sure what problem you are experiencing.
Was this part of an install or an upgrade of XI? If you have a specific error from an install or upgrade log it would help to post that and a few lines before and after for context, or just the whole log file.
