newbi quations about hosts and servics
grafix143
Post by grafix143 »
I am very new to Nagios , anyway I have it pre-installed i need to modify it a bit
I watched the self paced learning video but i still failed to carry out the task so i need help.
In the web interface under services in Nagios I have 4 number hosts to be checked which are printers they are not in use so i decided to remove them .
In nagios>congif folder there are two files which i found related to the printers
1- hostgroups.cfg
define hostroups {
hostgroup_name Printers
alias CUPS printers
members rlprt01,rlprt20,rlprt70,rlprt80
2. service_distants.cfg
services_description CHK - Print spooler
check_command check_lpqueue
notification_interval 0
so what I did is removing the
define hostroups {
alias CUPS printers
from the hostgroups,cfg then i used the command to restart nagios (service nagios restart) but i got an error which is
Configuration validation failed
Any suggestion how to make this works . i need to remove the printers check
screen shots attached
services_distants.zip
(31.88 KiB) Downloaded 291 times
Re: newbi quations about hosts and servics
define hostroups {
alias CUPS printers
Did you remove the entire hostgroup (Printers) or just the two members (hosts) that you wanted to remove? Which host the "CHK307 - Print spooler" service is attached to? The service is added to the "Printers" hostgroup, so it would show up under each host, member of this group, unless you remove the host from the "Printers" hostgroup.
What is the exact error that you see when you verify the configuration?
Note: If the path to the nagios binary or the main config file is different, please modify the above command accordingly.
grafix143
Post by grafix143 »
define hostroups {
alias CUPS printers
Ok , as I know if you have to put the *.cfg file in Nagios.cfg
but this is not case here , in Nagios.cfg they point to a folder where I find this hostgroups.cfg
and I have deleted the whole section from hotgroups.cfg
define hostroups {
alias CUPS printers
and then I did a restart and it failed ( Configuration Validation failed)
then I did your command so I ran this
( /usr/local/bin/nagios-sync -v /etc/nagios/nagios.cfg)
and the output is this
sending incremental file list
nagios/config/
nagios/config/hostgroups.cfg
I noticed this in your post
What is nagios-sync?
This leads me to believe it is more than just the nagios binary.
Does it by chance sync you configurations and then execute the commands to the real binary?
grafix143
Post by grafix143 »
scottwilkerson wrote:I noticed this in your post
Hi Scott,
TBH , I have no clue what are you talking about (real binary) and I also don't know what is nagios-sync , I was looking for the file nagios in this folder but I couldn't find anything else than nagios-sync .
I will try to search for what you just mentioned I may make sense out of it . :roll:
t3dus
Post by t3dus »
What I got from this is he deleted something that looked like
define hostgroup{
        alias           CUPS printers
from a file named "hostgroups.cfg" which I find a bit odd. None of my nagios files are simply called hostgroups.cfg so sounds like somebody did some modifying of file names.
Have you tried simply putting back in what you deleted? I included above what you deleted & corrected the misspelling you provided prior.
After you replace what you deleted then verify the config using
and then restart nagios and see if it fixes it.
grafix143 wrote:TBH , I have no clue what are you talking about (real binary) and I also don't know what is nagios-sync , I was looking for the file nagios in this folder but I couldn't find anything else than nagios-sync .
How was nagios installed on this server? Really before we proceed we need to know what we are dealing with because "nagios-sync" is not what the file should be called and is likely some modification.
