Nagios service on host name
anusha
Post by anusha »
Hi ,
By default the sever status is showing ping status and can display it as jvm status instead of ping. Can someone please help me with this
kyang
Re: Nagios service on host name
Post by kyang »
Could you show us a screenshot to clarify what you mean?
Thanks!
anusha
Re: Nagios default service on hostname
Post by anusha »
Hi Kyang,
By default we are getting server PING status for all the hosts but I want to change it one of the service status instead of ping status. Can you please let me know how to do it.
Post by mcapra »
This is done by altering the host's check_command, which would be redundant if you are already checking the JVM as a service.
A host's check_command cannot be "symbolically linked" or made to reference to a service check definition. Similarly, a host's status cannot be directly tied to the status of a service. This is a limitation of the objects themselves.
Thanks @mcapra for the help.
Pretty much all you would have to do is to edit the host check and make it the same as the existing service check.
If you need help doing this, please post the current host and service configuration so we can view the settings.
If you do figure out how to do this, since the host check is doing the same check as the service check, you may want to disable the service check as it is redundant.
anusha
Post by anusha »
Hi trgiep,
Thank you for your quick response. I have changed the check command form check_host_alive to check_jvm in templates.cfg under linux servers and it is working.
Thank you for your help....:) :)
npolovenko
Post by npolovenko »
@anusha, Do you have any other questions for us before I go ahead and lock this thread?
anusha
Post by anusha »
Yes you can lock this thread.
Thank you for your support...:)
