Hey Guys
So I'm looking at monitoring several hundred switches but I don't want to add each one individually and untick non critical ports
Basically - Im looking for a way to add a switch and only have it monitor interfaces that contain -{CRITICAL}
Is there a way to do this? Or is it not possible
Cheers
Cam
Monitor Interface Status by Description
npolovenko
- Support Tech
Re: Monitor Interface Status by Description
Hello, @camprior. There's no out of the box way to do this. You could modify the source code for the switch/wizard component in XI to include some conditional statement to do that.
If the critical ports are the same on all switches:
You could run a wizard against one switch, and then use a bulk modification tool to just clone the config to other switches.
Or do the critical ports vary on every switch?
hey @npolovenko
The critical switchports will vary from switch to switch unfortunately
Thats cool - I guess i could have a look at the switch component and attempt to add a statement to say only add interfaces that contain -{CRITICAL}
That way you don't end up with a million edge ports reporting as down and generating a critical event
Thanks for the reply
kyang
I would like to add that any changes you make to XI, will be overwritten if you do an upgrade. It's important to always make a back up in case anything happens.
Did you have any more questions?
