I'm just getting going with Nagios so a huge learning experience, but enjoyable
I have Nagios XI configured with the 0.4.4 NPRE client on a Windows 2012 server running websites. It's showing that the CPU is ramping to 100% in the middle of the night for a couple of hours, and the performance counter on the server shows w3wp.exe is the faulting process. However it recovers itself before I can see it. There are about 30 w3wp.exe process on this server which correspond to the same number of IIS application pools. The app pool name shows as the "Username" in task manager for each process.
Is there a way natively or a nagios plugin that will be able to identify which w3wp.exe process is going crazy occasionally?
many thanks
Rob
