CentOS 5, 32-bit, manual install.
When I use the check_ifoperstatus command, the Status Information line reads: check_ifoperstatus plugin for Nagios monitors operational
If I click the service to view the details I get the green check mark that all is ok plus I get the help output of the command. I'd like it just to return "OK". What am I doing wrong?
Running the command from the shell returns the values I would hope to see in the web page:
[root@nagios libexec]# ./check_ifoperstatus -k 7 -H 10.1.1.254
OK: Interface pppoe0 (index 7) is up.[root@nagios libexec]#Thanks
AwS
