Event Handler to run cleanup script at server end
johnwchen
Post by johnwchen »
Moderator Edit: This thread has been split from another - https://support.nagios.com/forum/viewto ... 16&t=47479
In the future, please create a new thread and link to the old one instead of adding on.
Support,
I have recently setup Event handler as well, do you recommend event handler or writing a plugin that just run the cleanup when a critical event happens? also, is there a way to us the contact macro from the host for the services? or the contact macro from the services for the event-handlers ?
kyang
Re: Event Handler to run cleanup script at server end
Post by kyang »
That is really up for you to decide.
Event handlers can be triggered by those critical events like a service failing, so that may be your route. But I don't exactly know what cleanup you are trying to do.
Your second question has been answered in another thread you created.
https://support.nagios.com/forum/viewto ... 522#244820
