[CLOSE]NRPE - fullinstall script problem
Boune
Post by Boune »
i'm trying to install NRPE on my Nagio XI , with the fullinstall script but i got an error with xinetd...
My debian version is 8.9
Linux wazo 3.16.0-4-586 #1 Debian 3.16.43-2+deb8u5 (2017-09-19) i686 GNU/Linux
Any help ?
thanks for reply
Re: NRPE - fullinstall script problem
The above statement (in red) doesn't sound right... You cannot be possibly running Nagios XI on Debian, and installing the Linux agent (NRPE + Nagios plugins) on the same machine... :)
I would assume that you are installing the Linux agent on a Debian box, that you want to monitor in Nagios XI (that runs on a different machine).
To start troubleshooting, let's first take a look at the /etc/apt/sources.list. Debian 8 likes to keep the cd rom in the repos section and uses that first. Can you try commenting it out, saving the file and running the following commands?
sudo apt-get clean
sudo apt-get update
If these command run successfully, then you could try rerunning the fullinstall script. Alternatively, you could try installing the xinetd first:
sudo apt-get install xinetd
then, running the fullinstall.
Let us know if this helped.
Boune
Post by Boune »
well , i install xinetd , and now the fullinstall is ok.
And yes i wanted to install NRPE on linux clientside :) not my nagios server.
Thanks a lot !
Glad to hear it! Are we alright to close this up then?
Boune
[Close] NRPE - fullinstall script problem
Post by Boune »
Yep , thanks !
