Monitoring engine status not running
btgnrw
Post by btgnrw »
The monitoring engine has stopped running on our instance and cannot be restarted via the GUI.
We are running 5.4.11 on RHEL 7.4
Can I restart from the command line?
btgnrw
Re: Monitoring engine status not running
Post by btgnrw »
I've resolved this now.
There was a host config file with errors in the check settings (invalid time period)
This host has now been deleted in Nagios XI GUI.
All Nagios engine services are now green.
kyang
Post by kyang »
Glad you found the issue!
Did you have any more questions or are we okay to lock this thread?
btgnrw
Post by btgnrw »
Feel free to lock.
kyang
Post by kyang »
Sounds good! I'll be closing this thread!
If you have any more questions, feel free to create another thread.
Thanks for using the Nagios Support Forum!
