Nagios XI Report showing all 0's
gthreadgill
The nagios xi availability report is displaying all 0's . I can select any host group and it is the same.
npolovenko
- Support Tech
Re: Nagios XI Report showing all 0's
Hello, @gthreadgill.
Please open the following config file on your system:
And change:
to
After that please restart the npcd daemon with:
Can you also generate a state history report for the same period of time that you generated the Availability report, and share it with us?
/usr/local/nagios/etc/pnp/process_perfdata.cfgCode: Select all
TIMEOUT = 5Code: Select all
TIMEOUT = 15Code: Select all
service npcd restartAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
