No output returned from plugin
morabanc
Post by morabanc »
Hi guys,
We have a service that gives an unknown state with this message:
- No output returned from plugin
It's strange because when we execute a "Force an immediate check" goes to ok state, but many minutes ago turns to unknown state once again.
This is the command configured in service (when we execute in shell goes fine).
- php $USER1$/script_salva_config_sql.php $ARG1$ 2> /dev/null ( where ARG1 is: router_one)
I attach you the configuration of template attach in service.
We are in 5.4.12 version.
kyang
Re: No output returned from plugin
Post by kyang »
I'm sure this is your custom plugin right? We will do our best to troubleshoot this issue, but we can only give limited information since we don't exactly know if your plugin is following our plugins-guidelines.
http://nagios-plugins.org/doc/guidelines.html
What template are you using for this service template?
Can you run your plugin from the command line and show us the output?
morabanc
Post by morabanc »
Hi kyang,
This is the output from command line:
bash-4.1# php script_salva_config_sql.php router1 2> /dev/null
OK: Fet la salva del host router1 amb data 2018-02-20 04:16:02. Caracters: 14335 | estat=1
bash-4.1#
Regards
kyang
Post by kyang »
Can you also provide the service check_command you are using for this?
And the command definition you have for using this php script?
All of this can be found in your Core Config Manager (CCM).
morabanc
Post by morabanc »
Hi kyang,
Here you are.
morabanc
Post by morabanc »
Also I attach you 2 pics, before do the force check and after do it
Are active checks enabled for this service? You can see on the Advanced tab
If so what frequency is the service being checked?
I have seen similar issue in the past, when mod gearman is used. The plugin is present on the server, and the check runs fine, when executed locally. However the plugin is missing on the mod gearman worker machine, so when it's run by the worker, it fails. Are you using mod gearman by chance? If you do, make sure that you have the plugin on the worker, and that you actually CAN execute this particular plugin remotely.
morabanc
Post by morabanc »
Hi guys,
Thank you very much for your comments.
@lmiltchev, we don't have mod_gearman.
@scottwilkerson, I attach some more config files.
morabanc
Post by morabanc »
And one more :)
