Query
Dharan
Query
Post by Dharan »
Hello All,
Hello All,
I downloaded the latest tar file from http://assets.nagios.com/downloads/nagi ... est.tar.gz, copied it to the Nagios base server using winscp and tried to install using ./fullinstall , but, I get an installation error that says ERROR: Subcomponent 'ndoutils' installation failed - exiting.
Subcomponents installation failed – exiting.
Please assist.
Dharan
Re: Query
What OS and version are you installing this on? Is it a clean, minimal install that has not been modified? Is there a GUI/desktop present?
If you have the full install.log from the installation directory that would be beneficial to share.
Dharan
Re: Query
Post by Dharan »
Please find the attachment of the install.log
Dharan
Re: Query
Post by Dharan »
OS is CentOS Linux release 7.4.1708 (Core). It is a clean install, it is just added to the space walk server to get all the packages
Re: Query
Post by mcapra »
Is this machine behind a proxy for it's internet access? I notice a whole lot of 401s when yum is requesting mirrors.
There are some steps to take when installing Nagios XI behind a proxy:
https://support.nagios.com/kb/article.php?id=147
You may also need to yum install systemd-devel.
npolovenko
Re: Query
Post by npolovenko »
@Dharan, Let us know if mcapra's article helped you solve this problem.
Dharan
Re: Query
Post by Dharan »
The proxy settings are transparent, the servers are blocked by the firewall from getting to the internet even if authenticated through the appliance.
Please let me know if there is a way to install Nagios XI without being able to access the internet or having the proxy settings?
I can ping 8.8.8.8 though
Dharan
Dharan
Re: Query
Post by Dharan »
Hello All,
The centos server on which I'm trying to install Nagios now has access to the internet, I'm able to wget the latest tar file, but, when I run the full install script I get an installationo error . Please find the attachment of the latest install.log and please review and let me know your findings
Re: Query
Most probably, you are missing some packages as your system didn't have Internet access, which caused compiling ndo utils to fail. Try running:
yum install systemd-devel -y
then rerun the "fullinstall" script.
BTW, I've never seen a CentOS machine, receiving updates from RHN Classic or Red Hat Satellite... (from the install.log). Are we troubleshooting XI install on CentOS 7.4? I am a bit confused.
DISTRO INFO:
CentOS
7.4.1708
x86_64
This system is receiving updates from RHN Classic or Red Hat Satellite.
Loading support for Red Hat kernel ABI
Dharan
Re: Query
Post by Dharan »
Hello All,
Thank you for all the replies, I re-built the base centos machine, got it access to the internet and was able to successfully install Nagios the second time. Thank you again
