Hi All,
Please help.
I'm working on a project using check_ncpa.py that will connect to the client using a plugin/check_ping. However, I always hit the wall that it cannot parse argument.
Command:
CMDLINE=/usr/local/nagios/libexec/check_ncpa.py -H <client_IP> -P 5693 -t 'Token' -M plugins/check_ping -H <client_IP> -w 10,2% -c 20,5%
OUTPUT=check_ping: Could not parse arguments
Usage:
check_ping -H <host_address> -w <wrta>,<wpl>% -c <crta>,<cpl>%
[-p packets] [-t timeout] [-4|-6]
RETURNCODE=3
Client Log:
2018-02-22 16:29:09,166 1857 INFO 10.105.162.82 - - [2018-02-22 16:29:09] "GET /api/plugins/check_ping/?token=Token&warning=10%2C2%25&critical=20%2C5%25&check=1 HTTP/1.1" 200 328 0.021117
Thank you
NCPA running plugin on the remote server/client
windkisser
kyang
Re: NCPA running plugin on the remote server/client
Does the client machine have NCPA installed? How about the plugins?
The client machine is a Linux server correct?
Did you add the path of the plugins in the ncpa.cfg on the client machine?
I'm running this check from my XI server to my client server that has the plugins and NCPA installed.
(I'm using the client IP address and token)
plugin_path = /usr/local/nagios/libexec/
./check_ncpa.py -H 192.168.4.174 -t 'xxx' -M 'plugins/check_ping' -a '-H 192.168.4.174 -w 10,2% -c 20,5%'
PING OK - Packet loss = 0%, RTA = 0.05 ms|rta=0.046000ms;10.000000;20.000000;0.000000 pl=0%;2;5;0-
windkisser
Hi Kyang,
Your suggestion worked for me.
I'm trying to make check_icmp work as well but no luck.
/usr/local/nagios/libexec/check_ncpa.py -H <ip> -P 5693 -t 'Token' -M plugins/check_icmp -a '-H <ip> -w 200.000ms,40% -c 500.000ms,80%'
kyang
On your client server, what are the permissions of check_icmp?
They should be this.
If not, please make sure the owner is as root nagios
Then change the permissions using this command.
Now run the check again from your remote server and connect to the client server.
ll /usr/local/nagios/libexec/check_icmpCode: Select all
-r-sr-xr-x 1 root nagios 227208 Jul 6 2017 check_icmp
chown root:nagios /usr/local/nagios/libexec/check_icmpCode: Select all
chmod u+s /usr/local/nagios/libexec/check_icmpCode: Select all
[root@localhost libexec]# ./check_ncpa.py -H 192.168.4.174 -t 'xxxx' -M 'plugins/check_icmp' -a '-H 192.168.4.174 -w 3000,80% -c 5000,100% -p 5'
OK - 192.168.4.174: rta 0.013ms, lost 0%|rta=0.013ms;3000.000;5000.000;0; pl=0%;80;100;; rtmax=0.042ms;;;; rtmin=0.005ms;;;;
