Hi support,
I'm using the check_asm, but when i direct run on the client server is show below result:
[root@XXXXXXX libexec]# ./check_asm --asm_home=/u01/installer/grid --action=dgstate
[CRITICAL] Diskgroup state: (: ERROR:) (invalid: ORA-01017:) (: ) (: ) (Invalid: SP2-0306:) (CONNECT]: Usage:) (logon>: where) (proxy>: ) (Invalid: SP2-0306:) (CONNECT]: Usage:) (logon>: where) (proxy>: ) (unable: SP2-0157:)
what is the problem? any configuration i need to configure?
check_asm
Re: check_asm
I found this in the plugin on how the plugin needs to be ran.
This plug-in needs to be run as ASM binaries owner (usually oracle).
The command you would need to use to run the plugin as the Oracle user is as follows.
Try that and let us know if it works.
sudo -u oracle ./check_asm --asm_home=/u01/installer/grid --action=dgstateBe sure to check out our Knowledgebase for helpful articles and solutions!
junqian1992
Re: check_asm
Hi tgrip,
Client server :
after i put the sudo -u grid :
[root@xxxxxxxxx libexec]# sudo -u grid ./check_asm --asm_home=/u01/installer/grid --action=dgstate
[OK] Diskgroup state: (DATA: MOUNTED)
in my common.cfg i set
command[check_asm]=sudo -u grid /usr/local/nagios/libexec/check_asm --asm_home=/u01/installer/grid --action=diskstatus
i already enable sudo for nrpe-owner to run this script
nagios ALL=(grid) NOPASSWD: /usr/local/nagios/libexec/check_asm
when i direct run the command:
sudo: unable to execute /usr/local/nagios/libexec/check_asm: Permission denied
nagios server :
but when nagios connect to using check_asm to collect result it show:
root@Nagios:/usr/local/nagios/libexec# /usr/local/nagios/libexec/check_nrpe -H XXXXXXXXX -t 30 -c check_asm
NRPE: Unable to read output
Client server :
nagios server :
Regards,
JQ
JQ
junqian1992
Re: check_asm
I know the problem already, i set the nagios folder to 755 then the command is running normal now.
Thank for your help .
Regards,
JQ
JQ
Re: check_asm
Your welcome. If you do not have any related questions, shall I close and lock the port?
junqian1992
