Backup nagios XI
Backup nagios XI
I have seen that i can a backup with Nagios, but we want to do a backup with Backup tool.
Can you tell me all necessary filesystems or directories to restore in case of errors, I can to do a restore?
Regards,
Regards,
Re: Backup nagios XI
I see that important files are in /usr/local/nagios and /usr/local/nagiosxi
I need to backup anymore?
Reagards,
Reagards,
Best bet would be to use the documentation posted to our Library on Backing_Up_And_Restoring_XI
This way you get database backups as well, and can restore.
Thank you for the information.
I will do this backup, but I need to do backup with backup tool of my company. About this I need to know, filesystems and directories that I need to copy
Regards
Regards
This will depend on your company policy on what is all backed up and what your setup is like.
The bulk of the Nagios/Nagios XI system are in the following directories, but this certainly isn't a full snapshot...
/usr/local/nagios
/usr/local/nagiosxi
/usr/local/nrdp
/store/backups
/etc/httpd/conf.d
/etc/xinetd.d/
/root/scripts
/usr/local/nagios
/usr/local/nagiosxi
/usr/local/nrdp
/store/backups
/etc/httpd/conf.d
/etc/xinetd.d/
/root/scripts
i can to have any document where appear all directories and files. I can't find this documentation.
Regards,
Regards,
Every install is different and your install may have other components that need to be backed up, however our backup script, backs up the following directories
/var/www/html/nagiosql
/etc/nagiosql
/usr/local/nagios
/usr/local/nagiosxi
and files
/etc/logrotate.d/nagiosxi
/etc/httpd/conf.d/nagios.conf
/etc/httpd/conf.d/nagiosxi.conf
/etc/httpd/conf.d/nagiosql.conf
And the 3 databases.
/etc/nagiosql
/usr/local/nagios
/usr/local/nagiosxi
and files
I exectuted backup script, baut appear:
/usr/local/nagiosxi/scripts/backup_xi.sh
[root@csplpa04 ~]# /usr/local/nagiosxi/scripts/backup_xi.sh
Backing up Core Config Manager (NagiosQL)...
tar: Removing leading `/' from member names
Backing up Nagios Core...
tar: /usr/local/nagios/var/ndo.sock: socket ignored
Backing up Nagios XI...
Backing up MySQL databases...
Backing up PostgresQL databases...
Backing up logrotate config files...
Backing up Apache config files...
Compressing backup...
/usr/local/nagiosxi/scripts/backup_xi.sh: line 103: zip: command not found
Where I can download zip? Can I modified script and used gzip and unzip?
msanbrug wrote:Where I can download zip?
yum install zip -yYou could but you would need to modify the restore script too..msanbrug wrote:Can I modified script and used gzip and unzip?
I installed zip command
Best Regards,
Best Regards,
