Services Not Working - Error 127.0.0.1:65009
annperegrina
Post by annperegrina »
Good day!
We are monitoring hundreds of Web servers as services in Nagios XI. we are using Appchecker.cfg. We are getting a lot of error "Services Not Working - Error 127.0.0.1:65009" (there several ports). What can cause this issue? As some servers are using same CFG file and working.
Please advise.
Ann
cdienger
Re: Services Not Working - Error 127.0.0.1:65009
Post by cdienger »
Can you see 65009(and other ports) open on the PG1047 machine? Run netstat -na on PG1047 to check.
What is the command being used to run this check? Is it using a nrpe agent to run the check?
