Return code of 4 is out of bounds
orani
Post by orani »
I get this critical error "Return code of 4 is out of bounds" sometimes at some checks.
Any ideas?
Re: Return code of 4 is out of bounds
Post by mcapra »
We need a bit more context.
What plugin(s) are being used for these checks that are sometimes failing? I'm assuming check_nrpe on the Nagios Core side of things? If so, what plugins is check_nrpe calling on the remote machine?
What operating system is Nagios Core installed on? What steps did you use to install Nagios Core?
orani wrote:I get this critical error "Return code of 4 is out of bounds" sometimes at some checks.
Any ideas?
If the plugin you are running is returning an exit code above 3 it is out of bounds.
Here is the section of the plugin development guidelines which is relevant
http://nagios-plugins.org/doc/guidelines.html#AEN78
