Checking Shadow Copy Status on Windows Servers
Is there an easy way to check a windows server to see if it's shadow copies are enabled. The VSS service only turns on when it's in use so I can't just check the service. I typically use NCPA for all my checks.
npolovenko
- Support Tech
Re: Checking Shadow Copy Status on Windows Servers
Hello, @cstarr. We do have a couple plugins on the exchange that you could use:
https://exchange.nagios.org/index.php?o ... ord=shadow
