Nagios- frequently not displaying HOSTS on GUI
svissa
Post by svissa »
Hi ,
Nagios is behaving weirdly. config is fine /nagios -v is giving 0 warnings and 0 errors.
But on Nagios UI. I have added 3 servers to hosts. Nagios UI is showing either one server or 3 servers. It is continously missing showing all servers all times.
Scenario:
Click on Hosts on Left Side page.
1. click - 3 servers
2. click for 4 / 5 times -- showing 3 server
3. Click for 5th or 6th time -- shows only one server
4. next 4/5 click shows only one server
5. 9th or 10th click shows all 3 servers.
whats wrong with the config ?
any help is appreciated.
mguthrie
Re: Nagios- frequently not displaying HOSTS on GUI
Post by mguthrie »
You might have multiple instances of Nagios running. Stop the nagios daemon, and then just to be safe, run:
killall -9 nagios
Then start the nagios process again. If you have multiple instance, they'll both overwrite each other's status information.
svissa
Post by svissa »
worked.
I did that the next hour i posted this issue. 3 instances of nagios are running.
I wnat to add DATE/TIME/TIMEZONE on nagios web page gui. How do to that? any idea ?
mguthrie
Post by mguthrie »
For that you've have to modify the source of the cgi's, and then recompile them.
svissa
Post by svissa »
if you have url references for this please share.
