From looking at a few posts on the forum I was wondering if it is possible to get syslog messages from devices using port 514 and 5544 on the Nagios Log Server.
If a person enables the logging of syslog messages by running logstash as the root user to listen on Privileged ports (514):
https://assets.nagios.com/downloads/nag ... 1519851299
then
Creates a Input filter in the Global Configuration:
and an Input filter of:
syslog {
type => 'syslog'
port => 514
will that allow the Nagios Log Server to receive syslog messages from devices on port 514 and 5544?
Getting syslog messages from two ports on Nagios Log Server
Re: Getting syslog messages from two ports on Nagios Log Ser
This is exactly correct
