Problem with Nagios NRPE
charly1986
Post by charly1986 »
I installed Nagios Core on a server, and I have several Windows clients monitored without any problem. Now I want to install the NRPE plugin in server and client to monitor a Linux client, too, follow the instructions for Nagios, but when I run the command. / Configure I get this error: "checking for SSL libraries ... configure: error: Can not find ssl libraries ".
The only thing I have found some support forums is that you need the package "libssl-dev" but I have it installed and I still shows the same error.
Did I leave any step in the installation?
regards
Re: Problem with Nagios NRPE
Run (in CentOS):
# yum list installed | grep openssl*
or run (in Ubuntu):
# dpkg --get-selections | grep openssl*
and post the output.
charly1986
root@revnagios:~# dpkg --get-selections | grep openssl*
libcurl4-openssl-dev install
openssh-client install
openssh-server install
openssl install
python-openssl install
nscott
Post by nscott »
Looks like you may need:
apt-get install libssl-dev
Nicholas Scott
charly1986
Already tried that command, and the result is this:
Reading package lists ... done
Building dependency tree
Reading state information ... done
libssl-dev is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
I think that I have installed this package.
P.D. I confirm that I have installed this package:
accountsservice install
base-passwd install
build-essential install
insserv install
less install
libaccountsservice0 install
libclass-accessor-perl install
libclass-isa-perl install
libclass-load-perl install
libclass-singleton-perl install
libgssapi-krb5-2 install
libgssrpc4 install
libnet-ssh2-perl install
libpciaccess0 install
libss2 install
libssh2-1 install
libssh2-php install
libssl-dev install
libssl-doc install
libssl1.0.0 install
openssl install
passwd install
ssh-import-id install
ssl-cert install
wireless-crda install
wireless-tools install
