check_ncpa.py plugin no longer working
doughnuts
Post by doughnuts »
G'day all,
I have a Nagios v4.3.4 instance running on CentOS 7 that includes usage of the check_ncpa.py plugin to monitor Windows hosts. This has been running fine for a while. We ran an update on Friday that pulled the latest NCPA plugin script from https://assets.nagios.com/downloads/ncp ... cpa.tar.gz, and it no longer works. I can see that the files have definitely changed as the new file is a bit larger in addition to the activity in GitHub. When running the plugin now I get this (which includes a return code of 127):
[libexec]$ ls -l check_ncpa.py
-rwxr-xr-x. 1 nagios nagios 10278 Feb 8 03:31 check_ncpa.py
[libexec]$ ./check_ncpa.py
: No such file or directory
Does anyone know of this issue, or can anyone provide some assistance in troubleshooting it?
kyang
Re: check_ncpa.py plugin no longer working
Post by kyang »
Please show us the location of check_ncpa.py
find / -name check_ncpa.py
Please run this from the command line and show us the output.
/usr/local/nagios/libexec/check_ncpa.py
doughnuts
Post by doughnuts »
I did include that info in my original post, though maybe I didn't present it clearly enough (probably should have formatted it better and included a pwd)
[~]$ sudo find / -name check_ncpa.py
[~]$ /usr/local/nagios/libexec/check_ncpa.py
Let's make sure it isn't dying right when it is looking for python
lets run
ls -al /usr/bin/env
which python
send them back to this post
lets also try
cd /usr/local/nagios/libexec
python check_ncpa.py
doughnuts
Post by doughnuts »
Seems like we're narrowing it down...
[libexec]$ ls -al /usr/bin/env
-rwxr-xr-x. 1 root root 28992 Nov  6  2016 /usr/bin/env
[libexec]$ which python
/usr/bin/python
[libexec]$ python check_ncpa.py
Usage: check_ncpa.py [options]
To add a bit more info: I have two separate environments, UAT and PROD. Both were running fine for months, and I know both are set up exactly the same as I use Ansible to configure them. A playbook was run on the UAT server the other day which pulled in a new version of the check_ncpa.py script and it hasn't worked since. PROD has not had the script updated and is still working fine. Given the outcome of the above test I checked the shebang at the top of both scripts and they are the same: #!/usr/bin/env python. The output of the commands I ran above are the same on both servers. Both servers are running Python 2.7.5.
Thanks for the assistance so far.
I'm guessing this is going to work but lets try it anyways, if you replace the shebang with this, does it work?
#!/usr/bin/python
Does it work?
And if so, we need to figure out why in this machine this doesn't return proper
/usr/bin/env python
doughnuts
Post by doughnuts »
G'Day Scott,
Thanks again for the reply. Output of your requests below:
[libexec]$ head -n 3 check_ncpa.py
#!/usr/bin/python
SYNOPSIS
-bash: ./check_ncpa.py: /usr/bin/python^M: bad interpreter: No such file or directory
[libexec]$ /usr/bin/python
Python 2.7.5 (default, Aug  4 2017, 00:39:18)
[GCC 4.8.5 20150623 (Red Hat 4.8.5-16)] on linux2
If I copy the check_ncpa.py file from our production server - it's the previous version - it works fine. In the output below, the .bak file is the most recent file from https://assets.nagios.com/downloads/ncp ... cpa.tar.gz and the .py file is the copy from our prod system.
[libexec]$ ls -l check_ncpa*
-rwxr-xr-x. 1 nagios nagios  9820 Mar  8 10:32 check_ncpa.py
-rwxr-xr-x. 1 nagios nagios 10274 Mar  8 10:27 check_ncpa.py.bak
Thanks again,
Matt
This means however this file was edited it got windows line endings on it
which leads me to an interesting question, when you downloaded it, how did you get in on the server? Did you download it directly and untar it, or did you download it to a windows machine and somehow copy the text for the file over?
I would strongly suggest doing this to get the file on the server:
wget https://assets.nagios.com/downloads/ncpa/check_ncpa.tar.gz
tar xzf check_ncpa.tar.gz
chmod +x check_ncpa.py
cp check_ncpa.py /usr/local/nagios/libexec/
doughnuts
Post by doughnuts »
I used the Ansible unarchive command, which downloads the file from assets.nagios.com directly to the target server and uncompresses it there. My Ansible control machine is also a MacBook so there were no Windows machines involved. Perhaps the packaged file itself has Windows line endings in it? Both the UAT and PROD servers were originally set up this way and worked fine until this new file. I'll try and directly wget it again tomorrow when I'm back at work just in case but I'm pretty sure I haven't altered that file in any way.
oh my goodness it does....
I have modified it and am attaching it here
I will contact the developer to have this adjusted
check_ncpa.py
(9.75 KiB) Downloaded 747 times
