Hello Team,
We have an sql server with a cluster and two nodes associated with it.
There are many NTFS mount points which are present on the server. We are trying to monitor those mount points using the below commands , but unknown error is coming. Please help at the earliest as this is really critical.
[nagios@ker-l-appmon01p ~]$ /usr/local/nagios/libexec/check_nrpe -H GEO-W-WISVCL11P.unity.media.corp -c CheckDriveSize -a Drive='N:\3PAR_IAM_SystemDBLogs' MinCritFree=15% MinWarnFree=20% Filter processing failed: Error: Failed to get size for: 3: The system cannot find the path specified.
[nagios@ker-l-appmon01p ~]$ /usr/local/nagios/libexec/check_nt -H GEO-W-WISVCL11P.unity.media.corp -s "umnagios123" -p 12489 -v USEDDISKSPACE -l M -w 90 -c 95 NSClient - ERROR: Invalid return from command: check_drivesize
Can we please have a webex session together, to solve the issue . We will need windows team also into the call as the server is windows server.
Please help at the earliest.
Regards,
Aditya Anand
NTFS mount point error!
Re: NTFS mount point error!
This will not work with NSClient++, see not at top of page:
https://docs.nsclient.org/reference/windows/CheckDisk/
Would it be possible to just check the share with a Samba plugin?
https://exchange.nagios.org/directory/P ... System/SMB
