mysql monitoring throwing stderr: /bin/sh errror
transline
Post by transline »
Moderator Edit: This thread has been split from another - https://support.nagios.com/forum/viewto ... =6&t=47771
In the future, please create a new thread and link to the old one instead of adding on.
Hello there,
ive got the same problem, i wanted to monitor a mssql server and got the same error.
So i tried your solution but it didn't work :(
Maybe i've done something wrong.
I installed dos2unix like u said, then i tried:
dos2unix /usr/local/nagios/libexec/ceck_mssql_server.py
don't know if this is the right plugin or not. I've only got the NagiosXi standard plugins, so have i really to convert this one?
Sorry im a completely beginner here, many thanks for help :)
cdienger
Re: mysql monitoring throwing stderr: /bin/sh errror
Post by cdienger »
Not sure if it was just a typo here but it looks like there was a typo in command. Try:
dos2unix /usr/local/nagios/libexec/check_mssql_server.py
transline
Post by transline »
yes it was a typo in my comment, the command was executet succesfully but it didn't help
what else could i do?
cdienger
Post by cdienger »
I've attached a good copy here in case the one you have still has problems. Replace the one on the system with this one and make sure the permissions/owernship is set:
chmod 775 /usr/local/nagios/libexec/check_mssql_server.py
chown apache:nagios /usr/local/nagios/libexec/check_mssql_server.py
transline
Post by transline »
i got it. My failure was a "!" in the userpassword, changed it, now its working :)
Glad to hear it! I'll be closing this up now, but feel free to open another thread if you need anything in the future!
