Reporting Explorer is not running, when it is.
mhedtcke
Post by mhedtcke »
Hi there. I am pretty new to Nagios. I have a server running the latest version of NSClient. It is reporting incorrectly that explorer isnt running. I am remoted into the server looking at the process manager with explorer running.
Everything else appears to be reporting properly (CPU, Memory, Up time, Storage).
Any ideas why this is happening?
Re: Reporting Explorer is not running, when it is.
What is the command that you are having nagios execute?
Please share the service description, the command definition
and results of running the command from the command line on the Nagios Server
mhedtcke
Post by mhedtcke »
Here is all of the references of DC01
use generic-service,nagiosgraph
host_name dc01
service_description NSClient++ Version
check_command check_nt!CLIENTVERSION
host_name dc01
service_description CPU Load
check_command check_nt!CPULOAD!-l 5,80,90
host_name dc01
service_description Memory Usage
check_command check_nt!MEMUSE!-w 80 -c 90
host_name dc01
service_description C:\ Drive Space
check_command check_nt!USEDDISKSPACE!-l c -w 80 -c 90
host_name dc01
service_description W3SVC
check_command check_nt!SERVICESTATE!-d SHOWALL -l W3SVC
host_name dc01
host_name dc01
service_description Explorer
check_command check_nt!PROCSTATE!-d SHOWALL -l Explorer.exe
these too please
scottwilkerson wrote:the command definition
by command definition I mean for check_nt
mhedtcke
Post by mhedtcke »
I'm sorry. I'm not sure what you mean by that. I see the check_nt plugin on the server but I'm not sure how to see it's config.
I mean how it is defined in the nagios configuration files. Maybe you have one named commands.cfg?
mhedtcke
Post by mhedtcke »
Got it. Thanks, here you go. Thanks for being patient with me.
command_name check_nt
command_line $USER1$/check_nt -H $HOSTADDRESS$ -p 12489 -v $ARG1$ $ARG2$
Can you run the following from the command line on the nagios server replacing IP_ADDRESS with the IP of dc01 and change the path of the plugin if your plugins are in a different directory, and then return the output
/usr/local/nagios/libexec/check_nt -H IP_ADDRESS -p 12489 -v PROCSTATE -d SHOWALL -l Explorer.exe
mhedtcke
Post by mhedtcke »
nagios01@nagios01:~$ /usr/local/nagios/libexec/check_nt -H 192.168.39.40 -p 12489 -v PROCSTATE -d SHOWALL -l Explorer.exe
Explorer.exe: not running
I RDP'ed into the server to ensure it was running and it is.
npolovenko
Post by npolovenko »
@mhedtcke, It's case sensetive, try with -l explorer.exe.
