Using check_remote_monit for RHEL7
CLee1972
Post by CLee1972 »
I have a number of servers using RHEL 6 that I have been monitoring without issue using the following "check_remote_monit" plugin (As well as other remote checks) *in usr/lib64/nagios/plugins*:
#!/usr/bin/perl
#Libraries
use strict;
use warnings;
use lib qw(/usr/local/nagios/libexec);
use feature qw(switch say);
#Pull Host variable from command.cfg
use Getopt::Long;
my $host = '';
GetOptions ('Host=s' => \$host);
#set pattern to search for
my $good_pattern = "is running";
my $warning_pattern = "not running";
my $critical_pattern = "is stopped";
#Get status variable from ssh and chomp it to remove new lines
chomp(my $status = qx|/usr/bin/ssh ${host} '/sbin/service monit status'|);
#Search for good pattern if not exit with error
if ($status =~ m/$good_pattern/)
        printf "OK:  %s\n", $status;
        exit(0);
}if ($status =~ m/$critical_pattern/){
        printf "CRITICAL:  %s\n", $status;
        exit(2);
}if ($status =~ m/$warning_pattern/){
        printf "WARNING:  %s\n", $status;
        exit(1);
printf "UNKNOWN:  %s\n", $status;
exit(3);
Unfortunately, RHEL7 had to change the way you look things up. I am wondering if Nagios has some updated plugin to use with RHEL7 to check statuses of Hardware (CPU, Disk_Drive, Memory, etc.) and well as specific services that we are checking for our application running on RHEL6 (And now RHEL7)?
Chris
Last edited by scottwilkerson on Wed Mar 07, 2018 2:22 pm, edited 1 time in total.
Reason: code wrap
CLee1972
Re: Using check_remote_monit for RHEL7
Post by CLee1972 »
Also, to follow up on this, I have tried to use check_process_snmp with a number of "Processes" and it keeps coming back with unknown status in the Nagios Core webpage. I am thinking this is not set right for RHEL 7.4 either:
!/bin/perl
use strict;
use warnings;
use Net::SNMP;
use Net::SNMP::Util;
use lib qw(/usr/lib/nagios/libexec);
use Getopt::Long;
my $host = '';
my $process = '';
GetOptions('Host=s' => \$host,
'Process=s' => \$process);
my $oid = '.1.3.6.1.2.1.25.4.2.1.4';
my ($session, $error) = Net::SNMP->session(
-hostname => shift || $host,
-community => shift || 'nagios',
if (!defined $session){
printf "ERROR: %s.\n", $error;
#my @result = $session->walk_request(-varbindlist => [ $oid ],);
my @result = '';
(@result, $error) = snmpwalk(
snmp => $session,
oids => [ $oid ],);
for my $i (0..$#result){
if ($process =~ m/$result[$i]/)
printf "OK: %s is running\n", $process;
exit 0;
$i++;
printf "ERROR %s is not running\n", $process;
exit 1;
I found this plugin you can use to monitor services on Redhat / Centos 7 servers that use the systemctl command.
https://exchange.nagios.org/directory/P ... ce/details
Try it out and see if it works for you.
CLee1972
Post by CLee1972 »
tgriep wrote:I found this plugin you can use to monitor services on Redhat / Centos 7 servers that use the systemctl command.
I believe this would work if I was running the service locally to the Nagios Core server but I am running it remotely. I have reached out to Taha to see if he has any ideas. Will keep you all updated.
OK, let us know if you have any more questions on this.
CLee1972
Post by CLee1972 »
I ended up going with NRPE. It just seemed like the next logical step on this, not to mention that it was able to do everything I needed from checking CPU, to verifying users logged in, Memory and watching all the processes and services that I had running on that machine. Thank you all for your help and input.
CLee1972
Your welcome. I'll lock the post for you but feel free to open a new post in the future if you have any other questions.
