Small bug, but the "import users" select all check box only works to de-select entries. If there are none ticked it doesn't do anything.
nagios 4 ldap integration select all bug
TheHutGroup
Re: nagios 4 ldap integration select all bug
Thanks this was previously reported and should be fixed in the next release
