Hi Team,
We running nagios XI server with below details.
Nagios XI Version - 5.4.2
OS - CentOS release 6.8 - 64bit
Currently we are running with "Python 2.6.6" we wanted to upgrade it to version "2.7.6".
Please let us know will the upgrade of python version affect our current nagios xi monitoring setup. if yes please guide us how can we upgrade python version to "2.7.6" without affecting our current monitoring.
Purpose of upgrade = use custom python plugins to monitor our infra which requires newer version of python.
Upgrading python version on nagios XI server
- tacolover101
Re: Upgrading python version on nagios XI server
i don't think this will affect anything, but the nagios folks would know best.
you could always compile python locally, and call to that upgraded version in your checks. eg. /opt/python276/
this link explains further - http://thelazylog.com/install-python-as ... -on-linux/
Thank you tacolover101 for your help.
@nagios team can you help me on this asap.
We can't foresee any problems with upgrading the python version and my CentOS 7 machine actually runs 2.7.5 which is a good sign, but we haven't actually tested this since CentOS 6 doesn't have a 2.7.6 package. Take the usual upgrade precautions of making backups of the system just in case and try it on a dev sever first if possible. Failing that, @tacolover101's suggestion of installing a second version of python and calling that when needed is a good one that has been recommended before on these boards.
npolovenko
- Support Tech
@lrnnetops, We only support the stock python versions that come with the OS. With that disclaimer mentioned, the key Nagios components do not really depend on python. My only concern is plugins compatibility. A lot of our plugins were written in python and if Python 2.7.6 has some different syntax rules the old plugin might not work. That is if you even use python plugins.
Hi Team,
We have upgraded python to 2.7 on test environment by alternate installation & it worked.
Please close this thread.
npolovenko
- Support Tech
@lrnnetops, Thanks for the update. Closing the ticket.
