3 instances, 2 vCPU's and 32GB RAM each. 62 open indexes, optimization after 2 days.
System Profile is attached.
For the past several months we've had an issue with a certain log file not keeping up (shipped via NXLog on Windows), as a workaround method we began restarting the log-sending service daily as this appeared to resolve it short term. In the past week this problem has intensified with no real change to log input levels, it is now affecting multiple logs from different source types. In looking into this I found that the Recv-Q in a
netstat -ntpFor the purpose of trying to keep this simple I'll show what I've found in regards to the original log type coming in from NXLog as a Windows Event log on TCP 3515 with the default input. Here are 4 successive
netstat -ntp | grep 3515Code: Select all
[root@srq-nagios-ls3 ~]# netstat -ntp | grep 3515
tcp 405 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.130:51058 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.35:54592 ESTABLISHED 21681/java
tcp 1274342 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.24:52260 ESTABLISHED 21681/java
tcp 3489066 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.49:49198 ESTABLISHED 21681/java
tcp 219 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.123:54340 ESTABLISHED 21681/java
tcp 3269416 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.55:49193 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.27:59551 ESTABLISHED 21681/java
tcp 219 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.126:58418 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.16:49417 ESTABLISHED 21681/java
tcp 3255556 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.13:49196 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.1.126:49201 ESTABLISHED 21681/java
tcp 3483670 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.65:50832 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.3.201:43098 ESTABLISHED 21681/java
tcp 3489693 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.69:56011 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.75:51676 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.212:49193 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.1.126:49223 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.1.126:49182 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.71:49877 ESTABLISHED 21681/java
tcp 3490424 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.48:49176 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.107:52745 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.38:50131 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.85:63105 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.79:49185 ESTABLISHED 21681/java
tcp 1106055 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.32:65310 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.59:49176 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.33:49197 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.1.115:37564 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.129:57378 ESTABLISHED 21681/java
tcp 3489706 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.204:63318 ESTABLISHED 21681/java
tcp 3484202 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.31:53547 ESTABLISHED 21681/java
tcp 3489762 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.72:51689 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.23:49194 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.20:49864 ESTABLISHED 21681/java
tcp 2225 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.130:51058 ESTABLISHED 21681/java
tcp 2960 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.123:54340 ESTABLISHED 21681/java
tcp 0 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.126:58418 ESTABLISHED 21681/java
tcp 3258760 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.13:49196 ESTABLISHED 21681/java
tcp 1125781 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.32:65310 ESTABLISHED 21681/java
tcp 1824 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.129:57378 ESTABLISHED 21681/java
tcp 673 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.130:51058 ESTABLISHED 21681/java
tcp 1257958 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.24:52260 ESTABLISHED 21681/java
tcp 3488958 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.49:49198 ESTABLISHED 21681/java
tcp 4098 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.123:54340 ESTABLISHED 21681/java
tcp 3275230 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.55:49193 ESTABLISHED 21681/java
tcp 675 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.126:58418 ESTABLISHED 21681/java
tcp 3260886 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.13:49196 ESTABLISHED 21681/java
tcp 3488190 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.65:50832 ESTABLISHED 21681/java
tcp 3489651 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.69:56011 ESTABLISHED 21681/java
tcp 3489639 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.48:49176 ESTABLISHED 21681/java
tcp 1135040 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.32:65310 ESTABLISHED 21681/java
tcp 1318 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.129:57378 ESTABLISHED 21681/java
tcp 3489541 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.204:63318 ESTABLISHED 21681/java
tcp 3489598 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.31:53547 ESTABLISHED 21681/java
tcp 3483702 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.72:51689 ESTABLISHED 21681/java
tcp 860 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.130:51058 ESTABLISHED 21681/java
tcp 1241574 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.24:52260 ESTABLISHED 21681/java
tcp 3484046 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.49:49198 ESTABLISHED 21681/java
tcp 3412 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.123:54340 ESTABLISHED 21681/java
tcp 1153 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.126:58418 ESTABLISHED 21681/java
tcp 3283528 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.13:49196 ESTABLISHED 21681/java
tcp 3489926 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.65:50832 ESTABLISHED 21681/java
tcp 1148263 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.32:65310 ESTABLISHED 21681/java
tcp 456 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.129:57378 ESTABLISHED 21681/java
tcp 3489708 0 ::ffff:10.0.1.173:3515 ::ffff:10.0.2.31:53547 ESTABLISHED 21681/java
Here is a result of a tcpdump for a minute from a bad source:
tcpdump -n dst port 3515 and host 10.0.2.49
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
12:17:58.096613 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 1364353879:1364353880, ack 3367158999, win 256, length 1
12:18:00.496735 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 0:1, ack 1, win 256, length 1
12:18:05.297087 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 0:1, ack 1, win 256, length 1
12:18:07.303163 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 0:1460, ack 1, win 256, length 1460
12:18:07.303235 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 1460:2920, ack 1, win 256, length 1460
12:18:07.303242 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 2920:4380, ack 1, win 256, length 1460
12:18:07.303247 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 4380:5840, ack 1, win 256, length 1460
12:18:07.303477 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 5840:7300, ack 1, win 256, length 1460
12:18:07.303488 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 7300:7637, ack 1, win 256, length 337
12:18:07.342863 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 7637:8275, ack 1, win 256, length 638
12:18:07.343670 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 8275:9735, ack 1, win 256, length 1460
12:18:12.352642 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 9735:10375, ack 1, win 256, length 640
12:18:12.354744 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 10375:11835, ack 1, win 256, length 1460
12:18:12.354762 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 11835:13295, ack 1, win 256, length 1460
12:18:12.354767 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 13295:14755, ack 1, win 256, length 1460
12:18:12.354772 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 14755:16215, ack 1, win 256, length 1460
12:18:17.363021 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 16215:16343, ack 1, win 256, length 128
12:18:17.672932 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 16343:16344, ack 1, win 256, length 1
12:18:18.272988 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 16343:16344, ack 1, win 256, length 1
12:18:19.483090 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 16343:16344, ack 1, win 256, length 1
12:18:21.883252 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 16343:16344, ack 1, win 256, length 1
12:18:23.073437 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 16343:17803, ack 1, win 256, length 1460
12:18:23.073470 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 17803:19263, ack 1, win 256, length 1460
12:18:23.073486 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 19263:20723, ack 1, win 256, length 1460
12:18:23.073492 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 20723:22183, ack 1, win 256, length 1460
12:18:23.073739 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 22183:23643, ack 1, win 256, length 1460
12:18:23.073751 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 23643:24042, ack 1, win 256, length 399
12:18:23.074805 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 24042:25502, ack 1, win 256, length 1460
12:18:23.074819 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 25502:25566, ack 1, win 256, length 64
12:18:23.075439 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 25566:27026, ack 1, win 256, length 1460
12:18:23.075451 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 27026:27085, ack 1, win 256, length 59
12:18:23.112892 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 27085:27521, ack 1, win 256, length 436
12:18:23.113117 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 27521:28012, ack 1, win 256, length 491
12:18:23.113349 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 28012:29472, ack 1, win 256, length 1460
12:18:23.113369 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 29472:30902, ack 1, win 256, length 1430
12:18:23.113827 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 30902:32362, ack 1, win 256, length 1460
12:18:23.113841 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 32362:32459, ack 1, win 256, length 97
12:18:23.114228 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 32459:32897, ack 1, win 256, length 438
12:18:23.453337 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 32897:32898, ack 1, win 256, length 1
12:18:24.053470 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 32897:32898, ack 1, win 256, length 1
12:18:25.253507 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 32897:32898, ack 1, win 256, length 1
12:18:27.653647 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 32897:32898, ack 1, win 256, length 1
12:18:32.452953 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 32897:32898, ack 1, win 256, length 1
12:18:37.154671 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 32897:34357, ack 1, win 256, length 1460
12:18:37.154702 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 34357:35817, ack 1, win 256, length 1460
12:18:37.154993 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 35817:37277, ack 1, win 256, length 1460
12:18:37.155003 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 37277:38737, ack 1, win 256, length 1460
12:18:37.155006 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 38737:40197, ack 1, win 256, length 1460
12:18:37.155011 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 40197:41049, ack 1, win 256, length 852
12:18:37.155698 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 41049:42509, ack 1, win 256, length 1460
12:18:37.155709 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 42509:42628, ack 1, win 256, length 119
12:18:37.195858 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 42628:43957, ack 1, win 256, length 1329
12:18:37.196301 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 43957:44676, ack 1, win 256, length 719
12:18:37.544277 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 44676:44677, ack 1, win 256, length 1
12:18:38.144349 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 44676:44677, ack 1, win 256, length 1
12:18:39.344442 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 44676:44677, ack 1, win 256, length 1
12:18:41.744611 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 44676:44677, ack 1, win 256, length 1
12:18:46.545001 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 44676:44677, ack 1, win 256, length 1
12:18:56.141592 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 44676:44677, ack 1, win 256, length 1
12:18:58.340561 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 44676:46136, ack 1, win 256, length 1460
12:18:58.340595 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 46136:47596, ack 1, win 256, length 1460
12:18:58.340602 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 47596:49056, ack 1, win 256, length 1460
12:18:58.340608 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 49056:50516, ack 1, win 256, length 1460
12:18:58.340612 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 50516:51976, ack 1, win 256, length 1460
12:18:58.340617 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 51976:52869, ack 1, win 256, length 893
12:18:58.379993 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 52869:54237, ack 1, win 256, length 1368
12:18:58.380645 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 54237:55697, ack 1, win 256, length 1460
12:18:58.380659 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 55697:55787, ack 1, win 256, length 90
12:18:58.380882 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 55787:57247, ack 1, win 256, length 1460
12:18:58.380893 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 57247:57380, ack 1, win 256, length 133
12:18:58.382846 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 57380:57989, ack 1, win 256, length 609
12:18:58.383256 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 57989:59449, ack 1, win 256, length 1460
12:18:58.383267 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 59449:60909, ack 1, win 256, length 1460
12:18:58.383273 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 60909:61430, ack 1, win 256, length 521
12:18:58.383968 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 61430:62890, ack 1, win 256, length 1460
12:18:58.383980 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 62890:62924, ack 1, win 256, length 34
12:18:58.384658 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 62924:64384, ack 1, win 256, length 1460
12:18:58.384671 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 64384:64469, ack 1, win 256, length 85
12:18:58.385147 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 64469:65925, ack 1, win 256, length 1456
12:18:58.423135 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 65925:66132, ack 1, win 256, length 207
12:18:58.423647 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 66132:67592, ack 1, win 256, length 1460
12:18:58.423661 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 67592:67726, ack 1, win 256, length 134
12:18:58.424082 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [P.], seq 67726:68229, ack 1, win 256, length 503
12:18:58.759749 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 68229:68230, ack 1, win 256, length 1
12:18:59.359800 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 68229:68230, ack 1, win 256, length 1
12:19:00.559895 IP 10.0.2.49.49198 > 10.0.1.173.must-backplane: Flags [.], seq 68229:68230, ack 1, win 256, length 1
tcpdump -n dst port 3515 and host 10.0.2.130
12:20:33.226117 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 1948922560:1948922797, ack 3957586243, win 256, length 237
12:20:33.226385 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 237:907, ack 1, win 256, length 670
12:20:36.226354 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 907:1144, ack 1, win 256, length 237
12:20:36.226670 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 1144:1363, ack 1, win 256, length 219
12:20:38.225669 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 1363:1550, ack 1, win 256, length 187
12:20:39.225664 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 1550:1787, ack 1, win 256, length 237
12:20:39.225958 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 1787:2006, ack 1, win 256, length 219
12:20:42.225382 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 2006:2243, ack 1, win 256, length 237
12:20:42.225709 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 2243:2462, ack 1, win 256, length 219
12:20:45.227665 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 2462:2699, ack 1, win 256, length 237
12:20:45.227942 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 2699:2918, ack 1, win 256, length 219
12:20:48.227221 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 2918:3155, ack 1, win 256, length 237
12:20:48.227553 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 3155:3374, ack 1, win 256, length 219
12:20:51.226130 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 3374:3611, ack 1, win 256, length 237
12:20:51.226471 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 3611:3830, ack 1, win 256, length 219
12:20:54.225371 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 3830:4067, ack 1, win 256, length 237
12:20:54.226011 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 4067:4286, ack 1, win 256, length 219
12:20:57.226002 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 4286:4523, ack 1, win 256, length 237
12:20:57.226291 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 4523:4742, ack 1, win 256, length 219
12:21:00.227997 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 4742:4979, ack 1, win 256, length 237
12:21:00.228305 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 4979:5198, ack 1, win 256, length 219
12:21:03.227713 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 5198:5435, ack 1, win 256, length 237
12:21:03.228025 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 5435:6105, ack 1, win 256, length 670
12:21:06.228337 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 6105:6342, ack 1, win 256, length 237
12:21:06.228704 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 6342:6561, ack 1, win 256, length 219
12:21:08.228426 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 6561:6748, ack 1, win 256, length 187
12:21:09.229078 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 6748:6985, ack 1, win 256, length 237
12:21:09.229373 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 6985:7204, ack 1, win 256, length 219
12:21:12.228258 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 7204:7441, ack 1, win 256, length 237
12:21:12.228585 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 7441:7660, ack 1, win 256, length 219
12:21:15.229242 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 7660:7897, ack 1, win 256, length 237
12:21:15.229584 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 7897:8116, ack 1, win 256, length 219
12:21:18.228770 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 8116:8353, ack 1, win 256, length 237
12:21:18.229152 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 8353:8572, ack 1, win 256, length 219
12:21:21.228870 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 8572:8809, ack 1, win 256, length 237
12:21:21.229189 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 8809:9028, ack 1, win 256, length 219
12:21:24.228714 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 9028:9265, ack 1, win 256, length 237
12:21:24.229033 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 9265:9484, ack 1, win 256, length 219
12:21:27.229013 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 9484:9721, ack 1, win 256, length 237
12:21:27.229287 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 9721:9940, ack 1, win 256, length 219
12:21:30.228435 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 9940:10177, ack 1, win 256, length 237
12:21:30.228743 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 10177:10396, ack 1, win 256, length 219
12:21:33.229511 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 10396:10633, ack 1, win 256, length 237
12:21:33.229841 IP 10.0.2.130.51058 > 10.0.1.173.must-backplane: Flags [P.], seq 10633:11303, ack 1, win 256, length 670
TCP Flag tcpdump Flag Meaning
SYN S Syn packet, a session establishment request.
ACK A Ack packet, acknowledge sender’s data.
FIN F Finish flag, indication of termination.
RESET R Reset, indication of immediate abort of conn.
PUSH P Push, immediate push of data from sender.
URGENT U Urgent, takes precedence over other data.
NONE A dot . Placeholder, usually used for ACK.
