Sometimes Nagios sends us false alarms about the previous configuration. For example, I changed the ssh port in two servers, and changed the configuration in my nagios, but sometimes it appears alarms in the ssh service
I deleted nagios.cache and nagios.precache and I restart the service, but the problem persists.
Has anyone suffered the same problem?
Thanks in advance,
my Nagios core 4.3.4 is crazy
Re: my Nagios core 4.3.4 is crazy
Sometimes this can happen if you have multiple Core processes running, often the result of an improper shutdown. Please run the following commands and post the output:
ps -ef | grep bin/nagios
mesobranlaspalabras
Good morning,
Thanks for replying
I executed the command and this is the results
thanks in advance,
Thanks for replying
[root@SrvNagiosCore1 ~]# ps -ef | grep bin/nagios
nagios 8497 1 0 Mar16 ? 00:02:20 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 8499 8497 0 Mar16 ? 00:00:10 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 8500 8497 0 Mar16 ? 00:00:10 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 8501 8497 0 Mar16 ? 00:00:10 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 8502 8497 0 Mar16 ? 00:00:10 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 8503 8497 0 Mar16 ? 00:00:10 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 8506 8497 0 Mar16 ? 00:00:10 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 8507 8497 0 Mar16 ? 00:00:13 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 8607 1 0 Feb14 ? 00:32:36 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 8609 8607 0 Feb14 ? 00:02:24 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 8610 8607 0 Feb14 ? 00:02:23 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 8611 8607 0 Feb14 ? 00:02:25 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 8612 8607 0 Feb14 ? 00:02:23 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 8613 8607 0 Feb14 ? 00:02:28 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 8614 8607 0 Feb14 ? 00:02:25 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 8615 8607 0 Feb14 ? 00:03:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
root 26748 26572 0 10:18 pts/0 00:00:00 grep bin/nagios
Reason: Please use [code][/code] tags around long output
Definitely multiple competing processes. Please run the following and post the output:
We have a KB article that goes over one of the issues that multiple processes can cause: https://support.nagios.com/kb/article/n ... ts-27.html
Particularly the "Possible Causes" section shows what a good output should look like.
service nagios stop
killall nagios
service nagios start
mesobranlaspalabras
Thank you very much for the help. Now Nagios works correctly.
Thanks again.
[root@SrvNagiosCore1 ~]# ps -ef | head -1 && ps -ef | grep bin/nagios
UID PID PPID C STIME TTY TIME CMD
nagios 6858 1 0 09:45 ? 00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 6860 6858 0 09:45 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 6861 6858 0 09:45 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 6862 6858 0 09:45 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 6863 6858 0 09:45 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 6864 6858 0 09:45 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 6865 6858 0 09:45 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 6866 6858 0 09:45 ? 00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
root 7775 6132 0 09:55 pts/0 00:00:00 grep bin/nagios
Reason: Please use [code][/code] tags around terminal output
Glad to hear it! I'll be closing this up now, but feel free to open another thread if you need anything in the future!
